Stock Hood - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 11th, 01, 04:00 PM Thread Starter
Does anyone have a smallblock with a Performer RPM intake, Edelbrock carb and a stock flat hood? I really want to use my stock hood but curious to see what others have done to get thiers to work.
68 RS, Ash Gold,pwr windows,Hounds tooth,355/T350,Autometer guage pod
CA420 is offline
post #2 of 7 (permalink) Old Apr 11th, 01, 04:20 PM
I've got a performer RPM with Holley 750 on my 70 z/28 and with a drop base aircleaner I don't have any clearance problems with stock hood. I think first gens have a little more to play with so you should be fine.
70 z/28 4sp,71 camaro hugger orange/white stripes,2000 v8 Grand cherokee.(Former Know it All)
zgator is offline
post #3 of 7 (permalink) Old Apr 11th, 01, 04:45 PM
i have an rpm with an edelbrock 600 and a flat hood,no problem just watch the height on your carbs wingnut stud.
ochrisl is offline
post #4 of 7 (permalink) Old Apr 12th, 01, 03:37 AM Thread Starter
Chris, what motor mounts are you using? My engine sits higher than the old one.
CA420 is offline
post #5 of 7 (permalink) Old Apr 12th, 01, 05:48 AM
Talking
I have the RPM and an Edelbrock 600 also. No problem using the stock flat hood. With a 2in. open element cleaner it is up against the insulation. Maybe you have 307 mounts? I've been told they're higher. I think there were 3 kinds of SB mounts...302,307,327-350. I could be wrong, if so I apologize. Good luck. I also use the energy suspension polyeurithane (sp?) motor mounts. Good luck ~ John
1968 RS, 355/4spd/12 blt w/3.55's.www.camarogenerations.com
John68rs is offline
post #6 of 7 (permalink) Old Apr 12th, 01, 01:11 PM
I have a 68 camaro with a stock hood and I want to put an edelbrock RPM Air-gap intake manifolk with an edelbrock 750 cfm. My question is do you think that it will all fit under the stock hood with the airgap and a K&N airfilter????
1968camaro123 is offline
post #7 of 7 (permalink) Old Apr 13th, 01, 03:52 AM Thread Starter
I think it will fit. I did some measuring last night and it looks like there is a one inch difference between stock and the RPM. The RPM and Airgap are the same height. I am looking at 1/4 inch that I need to drop and I should be good to go.
CA420 is offline
