air conditioning - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 28th, 01, 07:59 PM Thread Starter
has anyone used Vintage Air on a 69 big block? What side is the compressor on? I would like to keep the long water pump, but don't want the compressor on the drivers side due to the long a/c hoses. Any suggestions?
stmoore is offline
post #2 of 2 (permalink) Old Mar 28th, 01, 09:29 PM
YEP,
I have Vintage Air on my 69 396 BB. I ordered and installed the kit that puts the compressor on the PASSENGER side for several reasons. One, I didn't want to have to route all that "EXTRA" hose that is required when you put compressor on the driver's side. Two, if you ever want to put a centrifical supercharger on, it needs to go on the driver's side and it is MUCH easier to work around the alternator then it is the compressor.
You will need a SHORT water pump setup and basically a 68 pulley setup and bracketry. I also have power steering. On the alternator setup, use a GATES belt and a DEEP groove pulley and you won't have any problems with throwing belt at HIGH RPM.
GOOD LUCK.
Here is PIC:
http://fototime.com/95203A3C7890DC7/standard.jpg
[This message has been edited by sr71bb (edited 03-29-2001).]
sr71bb is offline
