67 Original Window Sticker - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 29th, 01, 05:12 AM Thread Starter
Daniel
Would anyone be willing to send me a scan of there window sticker? I am trying to figure out the last two digits of the RPO codes on the window stickers.
Daniel
67 RS/SS 350 2004R (owned since 81)
97 V6 5-speed Coupe (work car ordered new)
http://homestead.juno.com/dakcoffman/
67ss350camaro is offline
post #2 of 6 (permalink) Old Mar 29th, 01, 04:04 PM
Post your codes in the Tag Team section. I am sure someone will answer.
Silver69 is offline
post #3 of 6 (permalink) Old Mar 30th, 01, 06:06 AM
i have an original window sticker. I wont scan it for you but i can look at the rpo # for you.
1967 camaro 327 coupe
Performance engine looks great, cherry red all flush
timsisdope is offline
post #4 of 6 (permalink) Old Mar 30th, 01, 12:33 PM
William
William's Avatar
Those are called ECLs for exception control letter. Don't waste your time. You would need hundreds of window stickers to research them and at this time I do not believe all meanings will ever be known. I've been charting '69 ECLs for years. Some are easily understood, some options have several ECLs for no obvious reason. N40 power steering has 11 so far, Z22 rally sport has 15. JL8 has 2; one for 3:73, one for 4:10. Most engine options are AA for manual, AB for auto. Interiors also used them; I have 9 so far for midnight green standard. No idea what they mean - otherwise identical cars may have different ECLs.
William is offline
post #5 of 6 (permalink) Old Mar 31st, 01, 06:09 AM
frank
William, I have a AA ecl code for a 4.10 rear axle ratio JL8. Would you mind posting the one for 3.73. Thanks
frankk is offline
post #6 of 6 (permalink) Old Mar 31st, 01, 06:36 AM
William
William's Avatar
I believe you are refering to the ECL for the G84 4:10 axle ratio. When 3:73 was ordered as option H05 the ECL was also AA. The coding for 4 wheel discs seem to be 5JL8KQ for 3:73 and 5JL8LJ for 4:10.
William is offline
