What backspacing do i need for 17" wheels on my 68 camaro??? - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 19th, 00, 04:24 PM Thread Starter
I have just lowered my car and am about to order some American Racing Torque Thrust II's for my 68 camaro. I want to run a 17x7 in the front and a 17x8 in the back. I am going to run a 235/45/17 up front and a 275/40/17 in the back, but i dont know what backspacing i need to be safe?? can u help me out?? thanks
runninhorn is offline
post #2 of 3 (permalink) Old Mar 19th, 00, 04:55 PM
I'd go with 4.5" in the front and 5" in the rear. That size tire in the rear may be difficult to fit, unless the car sits really high in the rear. I had 225/40 18 on the front of my car with 4" backspacing and they fit fine, at full turn the tire would just barely hit rub the frame. If you get the 5" back spacing for the rear you may have to mount the shock inboard the frame. My best advice is to put some tires and wheels on the car now, find out the demensions of those tires (like the section width)and measure how much room you have, like space from the tire to the shock, tire to the frame, tire to the inner fender etc. Then find out the demensions of the tires you want to put on the car and see if you have enough room. Make sure you leave enough clearence for move ment of the tire due to cornering or going up an embankment, I would think you should have a minimum of 1/2". You can also try searching the archives in the tire and wheel section of this board, also I beleive there are a couple people that visit this board that have the same tire wheel combo you want.
MarkM is offline
post #3 of 3 (permalink) Old Mar 20th, 00, 11:38 AM
I'm running American Torque Thrust IIs - 17X7 and 17X8 with 4.5" backspacing and 245/45/17 front - 255/45/17 rear Comp T/As. The next size up in the Comp T/A line is 275's and they wouldn't fit on my '69 without going to custom backspacing on the wheels - which adds another $100 or so per wheel if I remember right. These fit good and don't rub even though my car is lowered a good 2". Check out my pics at the url below.
'69 400SB, Richmond 5-speed; '99 HD Road King Classic
www.geocities.com/sdenning1
RockyMtnRacer is offline
