10 bolt rear something's wrong???? - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 13th, 01, 08:53 AM Thread Starter
a 10 bolt posi rear in a 1970 camaro I am looking at has a 2.73 ? gear posi traction ,but when turning a corner you can hear and feel one tire jumping or chattering like there is no slipage at all .
how bad could this be ? Iam looking at a complete rebuild or a minor fix,the guy says he thinks it needs some posi lube
the car has a 454 motor/400 trans thats basiclly stock.
thanks
stock? 67
hidden 69
4 speed is offline
post #2 of 3 (permalink) Old Jun 13th, 01, 11:25 AM
Cool
Jack up one wheel, place trans in nuetral, apply beam torque wrench, turn wrench, should be no less than 35 ft/lbs to slip clutches.
Probably would drain fluid, clean out old fluid with a couple qts of kerosene, drain, add new lube, AND GM's diff additive. Do figure 8's in empty parking lot for several minutes, chattering should be gone. Otherwise, a clutch pak change is required, if gears are okay.
post #3 of 3 (permalink) Old Jun 13th, 01, 05:36 PM
Freddie
4 speed,
Check your post at engine and drivetrain.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is online now
