Cracked Powerglide Case - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 29th, 01, 06:08 PM Thread Starter
Friend gave me an aluminum powerglide tonight (I had to haul away) - only problem is case has a chunk broken off - a chunk around the bolt hole (2nd on drivers side) is broken off -
He still had the chunk....the bolt hole is intact - chunk is 3.5" x 4"
My question is - can this be welded back somehow? will it be strong enough to use again? or did I just move it from his junk pile to mine?
Dobek is offline
post #2 of 8 (permalink) Old Mar 30th, 01, 02:06 AM
the trans housing is Aluminum, you CAN weld it, but there so cheap just go get a rebuilt one and use the cracked one as the core,
Chris Edwards is offline
post #3 of 8 (permalink) Old Mar 30th, 01, 11:47 AM
i agree, i wouldnt trust a welded bellhousing. if the core is good it would be fairly inexpensive to have a transmission shop install the parts into a good case.
bottledpower is offline
post #4 of 8 (permalink) Old Mar 30th, 01, 11:58 AM
Thumbs down
There's nothing wrong with a welded trans housing, aluminum or cast other than the fact it is ugly. If you have the piece, and it is fairly large,(not something in a million pieces) find a shop that does aluminum welding. It will be just as strong, if not stronger than before. I've seen them run in street/strip cars and I personally run stock 3 speed saginaws in my stock car with welded ears. Once welded, I've never had them break at the weld. You just have to find a good shop with a qualified welder to do the job.
Racer#00
Plain Jane 67
76 Trans Am Stock Car
74 Z28 (Basket case)
Racer#00 is offline
post #5 of 8 (permalink) Old Mar 30th, 01, 12:40 PM
Where are you at in CAL I will give you a good one out of a 67.
oger is offline
post #6 of 8 (permalink) Old Mar 30th, 01, 02:46 PM Thread Starter
Talking
Oger - You Have Mail!
Dobek is offline
post #7 of 8 (permalink) Old Mar 30th, 01, 04:19 PM
MHR
Micky
Lightbulb
Depending on what you are doing, you can always put a Ultra-bell on it from JW Transmissions. It will hold high HP. Racing trans shops wil always take PG cases, broke bellhousings or not.
MHR is offline
post #8 of 8 (permalink) Old Mar 31st, 01, 03:36 AM
My '64 Impala been runnin since 1988 with the same portion welded. It snapped when I had a friend helping me install the engine and tranny into the car. He started to tighten the attaching bolts without taking each up a little at a time. Cost about $25 for the weld. Guy came right to the shop and did it. Buy time he was done it was barely noticeable. Its done alot.
elcamino is offline
