'67 factory air - Team Camaro Tech
post #1 of 9 (permalink) Old Nov 30th, 00, 08:12 AM Thread Starter
Rick
I am currentl restoring a '67 RS/SS 350 #124377N107985, VERY early car, fully optioned. The a/c has been butchered and we need to come up with a newused a/c setup from firewall forward. can anyone supply me with the part number for the right side case (fan side) I have a used unit but have doubts to its correctness.
Rick_Nelson is offline
post #2 of 9 (permalink) Old Nov 30th, 00, 10:15 AM
I have an early 67 327. Per the assembly manual the part number is/was 3885183. This is the "evaporator assembly." Hop this helps.
Mike67RS is offline
post #3 of 9 (permalink) Old Nov 30th, 00, 10:16 AM
I have an early 67 327. Per the assembly manual the part number is/was 3885183. This is the "evaporator assembly." Hope this helps.
Mike67RS is offline
post #4 of 9 (permalink) Old Nov 30th, 00, 10:32 AM Thread Starter
Rick
Cool
Thanks for the reply, unfortunately, I think thats the number for the evaporator and not the fiberglass box. The party we got this from took both stickers off from the evaporator as well as the Harrison decal off the box, so I can't even use that number. I am trying to verify the correct number off the box because that is the only identification mark left.
post #5 of 9 (permalink) Old Nov 30th, 00, 04:57 PM
Rick,
I have the complete assembly off my 67 now, wwhere would the # you are looking for be located on the outside box, which I think is the same regardless of engine size. The inner half and evaperator are different for big block.
69 rallye green X77 Z/28,1967 SS 396 Conv. 1974 c-10 454 swb
pipeman is offline
post #6 of 9 (permalink) Old Nov 30th, 00, 05:31 PM
I just checked mine (12C Los car) - can't find any numbers on the fiberglass box - are you talking numbers on the harrison tag??
Dobek is offline
post #7 of 9 (permalink) Old Dec 1st, 00, 02:02 AM Thread Starter
Rick
There are two numbers on the INSIDE of the box just under and left of the heater fan motor hole. One number I believe is the Harrison part number as it says (if I recall) HPN# _ _ _ _ _ _. Just under that is what looks like a Chevrolet part number. I would like both just in case. I have found no other numbers anywhere on either case half.
post #8 of 9 (permalink) Old Dec 1st, 00, 04:55 PM
My 327 fiberglass AC case has the following under the fan motor hole inside: HRD P/N 3010077 with FP in a circle at the end.
On the smaller inboard half I cannot find a number, just the Harrison sticker near the center outside.
bonecrusher67conv is offline
post #9 of 9 (permalink) Old Dec 3rd, 00, 07:50 AM Thread Starter
Rick
Talking
Thanks, though I believe that to be the Harrison number and not the Chevrolet number, It does indeed match the one I just received, so that is a big help and I might be able to use it though it is very "weathered". Thanks to all for responding.
