Universal Bell Housing - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 1st, 01, 05:09 AM Thread Starter
I was thinking about putting in a 5-speed from a mustang in my Camaro (don't give me a hard time guys about mustangs). The 5-speed in Camaros can't handle the HP and the Mustangs is supposed to be tougher.
My question is, is there a universal bell housing that will allow you to mate a ford trans to a chevy engine? Also is there anything else I would have to change besides mating U-jouints? (Can't afford a 6-speed!!!)
Thanks, Tony
obnoxious 67 camaro under construction. TH350/383 stroker w/ aluminum Edlebroc RPM heads,cam, and carb.
OBNXUS67 is offline
post #2 of 5 (permalink) Old Jun 1st, 01, 06:58 AM
Those tremec transmissions from Fortes Parts connection (waltham mass) are 5 speed ford type units, that have been modified to accomodate a GM bellhousing perhaps you can do the same??
do a search here for some more info on the tremecs
68ragtop is offline
post #3 of 5 (permalink) Old Jun 1st, 01, 12:28 PM
Gene
The Mustang T-5 has a different input shaft and will not fit in a Chevy. Forte's had a custom input shaft designed and manufactured specifically for their Chevy applications.
Pearl blue & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 4/16/01 at:
www.geocities.com/gheatly
gheatly is offline
post #4 of 5 (permalink) Old Jun 1st, 01, 06:22 PM
JohnZ's Avatar
The T-5 isn't very stout - what are you bolting it up to?
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #5 of 5 (permalink) Old Jun 2nd, 01, 06:49 AM Thread Starter
The transmission is for my 67,383 stroker,about 425-450 HP.
GHEATLEY- couldn't you put a ford clutch on it to take care of the diff in input shafts?
Unless someone wants to buy a T-10 4-speed AND a TH350 so I can buy Forte's Tremec?
Tony
OBNXUS67 is offline
