Accessory switch on column - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 1st, 01, 05:49 AM Thread Starter
Donnie
Send a message via MSN to 69DZ302
I have a '69 Z28, and I changed the column to a tilt and kept my key cylinder from the old one and put it in the tilt. The problem I'm having is I can't get the key to go in the accessory position. I've tried loosening the two screws on the part located on the column down toward the bottom and moving it back and forth but the key still won't turn back to accessory. Would it help or not if I took the part off of my old column and put it on the tilt. Thanks, Donnie...
69DZ302 is offline
post #2 of 8 (permalink) Old Jun 1st, 01, 07:00 AM
The lock cylinder turns a gear that moves a rack, that pulls a lever to the ignition switch. It sounds like the rack might have slipped a tooth?
TTFN
Mat
Mat Klemp is offline
post #3 of 8 (permalink) Old Jun 1st, 01, 07:05 AM
Did you have new keys made? I had this same prob and found it to be new keys would start the car but wouldn't allow the switch into the accessory position until I wire brushed (fairly aggressivly) the keys. Might be a quick fix.
Sleepy-69 is offline
post #4 of 8 (permalink) Old Jun 1st, 01, 07:13 AM Thread Starter
Donnie
Mat, The rack that you are speaking of, is it possible to change it out of the tilt and replace it with the one from the other column. If not, what needs to be done at this point if anything. Would replacing the part at the lower portion of the column I spoke of help at all or would replacing the lock cylinder help. Thanks for the reply, Donnie...
69DZ302 is offline
post #5 of 8 (permalink) Old Jun 1st, 01, 07:29 AM
I don't think that the column pieces are interchangable from tilt to non tilt. you shouldn't have to replace parts unless they are broken, just reposition them. Try the key trick first, make sure the lock cylinder will turn to accessory when it is not installed. You may also try disconnecting the ignition switch rod to make sure the switch isn't holding it up.
TTFN
mat
post #6 of 8 (permalink) Old Jun 1st, 01, 07:33 AM Thread Starter
Donnie
Mat, To disconnect the rod, is that done where I remove the part at the lower portion of the column. Where does the rod attach on both ends. Thanks, Donnie...
69DZ302 is offline
post #7 of 8 (permalink) Old Jun 1st, 01, 07:46 AM Thread Starter
Donnie
Sleep-69, I haven't made any new keys but the previous owner did give me two sets of keys, but I don't know if I've tried both sets or not in the accessory position. I will try them both and see if that helps. Thanks for the reply, Donnie...
69DZ302 is offline
post #8 of 8 (permalink) Old Jun 1st, 01, 06:35 PM
JohnZ's Avatar
Did you try the Shop Manual procedure for adjusting the switch? Leave the two screws loose that attach the switch, turn the key to the "Lock" position, and pull the little pin (in the slot on the side of the switch) all the way to the rear ("Lock" position for the slider in the switch) and hold it there, and tighten the two switch screws.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
