Engine Paint - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 23rd, 00, 03:02 PM Thread Starter
Does anyone know where to buy hi-temp engine paint in custom colors? I want to re-paint the engine to match the car, 74 Porsche-Guards Red. Some people have told me that the same paint I used on the car would work but, I am afraid it will burn off or discolor. Any thoughts?
GGRIFFIN is offline
post #2 of 6 (permalink) Old Aug 23rd, 00, 03:10 PM
Thumbs up
Normal paint will hold up fine, I've had it on my engine for sometime now and I know of many others who have done the same.
68 468 700R4, and here it is;
mutert23
MarkM is offline
post #3 of 6 (permalink) Old Aug 23rd, 00, 03:46 PM
Cool
I painted my block BRIGHT yellow 5 years ago.
I used VHT yellow hi temp paint as a base then used my bright yellow as a topcoat. 5 years and still bright as ever. Sean
[This message has been edited by SAyers69 (edited 08-23-2000).]
SAyers69 is offline
post #4 of 6 (permalink) Old Aug 24th, 00, 05:24 AM
Just like Mark said, I had a co-worker use car paint on his and it seems to be doing fine.
67 Camaro SS Conv.
70 Challenger R/T Conv.
ragtopman is offline
post #5 of 6 (permalink) Old Aug 24th, 00, 06:40 AM
Michael
Cool
I like SAyers69's idea, use a Hi-Heat base coat that is close to your Guards Red, and then spray on the actual Guards Red as the top coat. Just be absolutely sure that the two paints are compatible, maybe you can try painting something other than the engine with both coats first to make sure that there is no adverse reaction.
1969 RS/SS CAMARO
350 / 4 spd. Rallye Green
1NAST69 is offline
post #6 of 6 (permalink) Old Aug 25th, 00, 07:11 PM
We usually just give engines a light coat of DP Epoxy primer then your normal automotive paint(PPG, ect.). Holds up better than ANY spray bomb.
Austin
Austin is offline
