bad vibration from drive train - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 16th, 01, 04:39 PM Thread Starter
I have a bad vibration that comes up from the gear shifter ad from the floor board and rear end. It started off as a small vibration that started when you let off of the throtle doing 85 or so no it is a constant vibration from 70 and up. I have replaced the u-joints and had the drive shaft ballanced. please help.
RSBell11 is offline
post #2 of 8 (permalink) Old Feb 16th, 01, 05:14 PM
Larry
I had a vibration such as that it was so bad it would knock the car out of fourth gear. Turned out to be a worn out pilot bushing.
ldrisner is offline
post #3 of 8 (permalink) Old Feb 17th, 01, 03:47 AM
Check the pinion nut on the rearend. Sometimes they loosen up.
69 RS/SS 427 4.11's
2000 Z28 Navy Metallic LS1 6 Spd T-Tops
Spooky is offline
post #4 of 8 (permalink) Old Feb 19th, 01, 05:39 PM
Check trans mount. make sure no part of drive train is in contack with the car body. ie. shifter, shifter rods. mounting bolts ect. Had this happen to us once Made the hole car shake.
mike's 68 is offline
post #5 of 8 (permalink) Old Feb 20th, 01, 08:37 AM
I have the very same problem. Won't be able to work on my car for another 30-40 days. Did the wheel bearings and u-joints, no help.
Tossing the 10 bolt for a reworked 12 bolt posi this spring and putting on 84 aluminum drums. (Lighter, dissipates heat faster.) I pray that fixes the problem. It's the only thing left. I'll write back when I figure it out or when I've spent too much money.
With all the thinking that has gone into this, I think one of the drums has lost a weight.
Rick O'Loughlin
Scoop69RS-SS is offline
post #6 of 8 (permalink) Old Feb 20th, 01, 09:58 AM
Double check that driveshaft despite having new ujoints and balance. Put the backend in the air, good jackstands under the axle tubes and start the car, put it in first gear. Take a good look at the driveshaft fom the side of the car. For safety sake don't get under the car. Anyway, if you see any "bouncing" of the driveshaft pull it back out and bring it back to the guy that did the work for you and ask him whats going on.
BIGDOG454 is offline
post #7 of 8 (permalink) Old Feb 21st, 01, 05:39 PM
I had vibration coming from my rear end when a couple tire balancing weights fell off and produced speed specific vibration that would decrease with acceleration. I have Cragar SS mags. Got tire shop to look and they rebalanced--vibration is gone.
backfire is offline
post #8 of 8 (permalink) Old Mar 8th, 03, 07:42 AM
dave
tire out of balance?
1968 camaro 327/210hp
1965 chevelle 283/195hp
1972 cheyenne super
...wife & 3 great kids
Z11/396 is offline
