Radiator transmission cooler ??'s - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 24th, 00, 05:26 PM Thread Starter
Chris
I'm going from a SB to a BB with a TH350. My question is I was going to buy an aftermarket radiator. Yet, what do I do with
the aluminum hoses going from my original
transmission to my TH350. Ya, I take them
out but, do I just put some plugs in my
transmission or what??
Procharged69 is offline
post #2 of 4 (permalink) Old Mar 24th, 00, 06:02 PM
If you need to run a trans cooler, either the one in the radiator or an aftermarket. If you plug the lines coming out of the trans you will be replacing that too. Most "aftermarket" radiators will come with the cooler in the tank, this is barely sufficient for stock applications.
Steve R.
Steve R is offline
post #3 of 4 (permalink) Old Mar 28th, 00, 05:39 PM
Lonnie
Steve is correct, do not plug your cooler lines. You should buy the biggest tranny cooler that will fit. Your tranny will last longer. If you use the radiator and a cooler make sure the fluid goes to the radiator first. I prefer not to use the radiator, only a cooler. Some people disagree...
67 410sb 11.76 @116.6
Lonnie67 is offline
post #4 of 4 (permalink) Old Mar 29th, 00, 05:20 AM
I would never advise anyone to plug the cooling lines in their transmission, especially when increasing performance and (if applicable) installing a higher stall torque converter!
As far as cooling goes, many aftermarket manufacturers recommend running the external cooler in series (out from) the radiator because the net temperature loss will be greater than just using the external cooler in itself, no matter how large it is. Also, only one cooling line has to be modified in this configuration, as opposed to cutting both of them to run to the external cooler only.
http://www.geocities.com/dmdirks/Automotive.html
RacerX is offline
