TH400 ID Numbers on SS396 - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 22nd, 01, 07:59 AM Thread Starter
Dana
I just bought a '69 SS396, TH400. The past owners all say the trans is the original and I am sure it probably is but I can't find any ID numbers on it! McNiesh and Hooper all say RH side but no pics for reference. I have looked with light, mirror and rag I cant find anything. Where EXACTLY are they? Are they stamped in the cast like a Muncie 4-spd or on a metal tag or ? Any help would be appreciated!!
1969 RS-Z/28: Matching #'s DZ302, M20, 3.73, Tuxedo Black, Deluxe Black Interior, Factory Tach, Clock and Console Gauges, PS, Rear Defrost, Spoilers, ZL2 Special Ducted Hood.
1969 SS: Matching # 350/300, M20 4-spd, 3.55 12-bolt posi, Daytona Yellow, Black Deluxe Houndstooth, Factory Tach, Clock and Console Gauges. Front and Rear Spoilers.
'85 Z/28, 355 TPI w/ Crane Compu-Cam 2040, Crane adjustable fuel pressure regulator, 22# Injectors, TPIS Airfoil, K&N filters, Hypertech ThermoMaster Stage 2 Chip for '85 Vette, 160 Degree Thermostat, DynoMax Cat Back Exhaust, Rebuilt/Updated 700R4 w/shift kit, 3.23 posi rearend.
DWCamaro69 is offline
post #2 of 7 (permalink) Old Apr 22nd, 01, 10:02 AM
William
William's Avatar
There should be a small metal tag riveted to the RH side of the trans several inches back from where the dipstick tube enters the case. Look for the cast-in ribs on the case. It is common for rebuilders to remove the tag.
VIN stamps are often found on the LH lip of the bellhousing. If it is there you should be able to see it behind the LH cylinder head.
William is offline
post #3 of 7 (permalink) Old Apr 22nd, 01, 06:01 PM
Joe
Talking
I was going to say you have too many Camaros for one person, but then decided there is no such thing!!
Joe
69 396 w/SS Trim
[email protected]
69 Pics http://albums.photopoint.com/j/Album...559&a=11674961
Joe G is offline
post #4 of 7 (permalink) Old Apr 22nd, 01, 06:13 PM
look on the passenger side where the tailshaft meets the the housing. Your VIN should be stamped there.
camaroguy is offline
post #5 of 7 (permalink) Old Apr 22nd, 01, 07:00 PM Thread Starter
Dana
Cool
Thanks for the help guys! The previous owner had the trans rebuilt at a shop so the tag appears to be gone. Will check for the VIN where you suggested William. Joe G, you are correct, there is no such thing as too many Camaro's. Camaroguy, I think you are refering to VIN location on a manual trans. I know where to find those numbers as all my other '69's have been 4-spd cars.
post #6 of 7 (permalink) Old Apr 23rd, 01, 04:34 AM
Nope. I have had many that were located in that position as well as the Muncies. Good luck.
68 RS red w/ white stripes
67 SS/RS restoring
post #7 of 7 (permalink) Old Apr 23rd, 01, 05:00 AM Thread Starter
Dana
Cool
OK camaroguy, I will look here too. Thanks!
