Adjusting Rockers - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 23rd, 01, 05:08 AM Thread Starter
I just TRIED to adjust my rockers this weekend. I loosened them on one bank at a time I could spin the push rods. Then I would tighten it 1/4 of a turn. is this too much? Or should I just tighten it until I cant spin the push rods any more?
I need help thanks
obnoxious 67 camaro under construction. TH350/383 stroker w/ aluminum Edlebroc RPM heads,cam, and carb.
OBNXUS67 is offline
post #2 of 6 (permalink) Old Apr 23rd, 01, 05:18 AM
Bill
If you used your method while the engine was running at idle, it should work. If you used your method with the engine off and not properly locating the rockers, you'll be way off. Do a search on rocker adjustment...there are several posts regarding more than one method to adjust rockers.
'72Z & '67 Chevelle.com
wlpz28 is offline
post #3 of 6 (permalink) Old Apr 23rd, 01, 05:34 AM
DjD
DjD's Avatar
You guys need to dig around this site and discover the vast wealth that is beyond the forums... Here is an example: www.camaros.net/techref/ftecref17.html
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
post #4 of 6 (permalink) Old Apr 23rd, 01, 06:32 AM
I have these little covers that go over the rockers to prevent oil splatter, I then back them off untill they make noise, then tighten till they stop. then 1/4 to 1/2 more , repeat 15 more times and your done.
Although with a new cam and lifters you may have to repeat a few times while the lifters pump up.
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #5 of 6 (permalink) Old Apr 23rd, 01, 02:30 PM Thread Starter
Thanks DjD,
Thats just what I needed. I probably got mine too tight. Going to try it again.
Thanks again, Tony
OBNXUS67 is offline
post #6 of 6 (permalink) Old Apr 23rd, 01, 06:23 PM
easiest way to adjust rockers-
bring #1 cyl to TDC on the compression stroke adjust exhaust valves on cyl 1,3,4,8 to zero lash (zero lash is the point when the pushrod no longer spins freely between your fingers) then 1 full turn. adjust intake valves on cyl 1,2,5,7 the same way. now rotate the engine until the damper lines up at zero again (#6 TDC compression stroke) adjust exhaust valves 2,5,6,7, and intake valves 3,4,6,8
it might sound complicated but its really simple and way faster than other methods.
bottledpower is offline
