zz430 - Team Camaro Tech
post #1 of 7 (permalink) Old May 3rd, 01, 07:21 PM Thread Starter
hi is anyone out there using sanderson qp1000 cast headers with the fast burn heads i plan on installing a zz430 (#340) IN my 69 z-28 richmond 4+1 trans.with power steering. can anyone give me any help on fit and performance of this header in my car thanks
camarogator340 is offline
post #2 of 7 (permalink) Old May 4th, 01, 03:26 AM
Thumbs up
I am going through this as I type this. I have a zz430. I have the Sanderson Q1000 on it now. I need to put the motor in the car...maybe today. I will then bring it down to the muffler man on tuesday to have the exhaust finished. The only thing I noticed is that the q1000 ports were not quite as wide as the D-port fastburn heads. I wasn't happy about that but that is what I am going with. I will let you know how things go. I am in Michigan also.
Jammer
1969 Z-28
[This message has been edited by Jammer (edited 05-04-2001).]
Jammer is offline
post #3 of 7 (permalink) Old May 4th, 01, 07:33 PM Thread Starter
thanks jammer for the reply. i just got my qp1000 headers today, you are right about the ports,looks good on the engine though.i hope they work out for us,while test fitting the header i noticed the header flange covered the two bolt holes for the bowtie wire looms.how did you mount yours? i am a little behind you in my project,are you using a manual or auto trans? i will keep you up to date also.
post #4 of 7 (permalink) Old May 4th, 01, 08:38 PM
Cool
the main concern should be the top of the hedder or the roof of the port.if it matches here it shouldn't be too bad.this is the highest flow area exiting the port.if ti hangs down here you may want to consider something else, maybe some super comp hedders and have them ceramic coated.
sldhd is offline
post #5 of 7 (permalink) Old May 5th, 01, 02:27 AM
Gator,
I am also running fastburn heads (on a '79 Z28) and ended up going with Sanderson block hugger style headers with "FB" suffix on the part number (meant for fastburn heads). This is the only soultion to my knowledge (and I did look) for those of use that manual trannies.
Jim Pace GM Parts warehouse sells a Hedman header that also fits fastburn heads for auto trannies only.
MikeM79 is offline
post #6 of 7 (permalink) Old May 5th, 01, 04:33 PM Thread Starter
thanks for the info mike and sid the port overlap is at the width so maybee were ok,some people on the net said they had problems with fit on the f/b head 1st generation camaros with hedman and hookers so i ended up at sanderson. ill keep updates
post #7 of 7 (permalink) Old May 5th, 01, 09:11 PM
I am using a manual transmission. The header does overlap the wire loom bolt holes. I also have the Dr. Gas crossover setup. I will try and keep you posted how it goes.
Jammer
Jammer is offline
