msd ignition - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 28th, 00, 05:45 AM Thread Starter
hey guys,i have a 1995 z28 camaro.i was wondering what msd ignition should i get.my car is an automatic trans.what are my benifits of this,and what does it do.will my car run better,and is it easy to install.someone email me or help me.that would be great.from bino.
z28lt1350 is offline
post #2 of 6 (permalink) Old Aug 28th, 00, 06:48 AM
Gene
I would get a 6-A. You don't need the rev limiter in the 6-AL, so why spend the $$.
Hugger Orange & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 8/13/00 at:
www.geocities.com/gheatly
gheatly is offline
post #3 of 6 (permalink) Old Aug 28th, 00, 06:49 AM
They are easy to install, and very straight forward, the instructions included with them are good. It will give you a much cleaner burn due to the multiple spark discharge, it raises RPM potential over HEI's and will likely improve idle characteristics as well. You will also need MSD wires, because a 6 series MSD will cook solid core wires. On your 95- I'm not sure how much gain you'll see, but on my 400 SB I see a huge difference over the HEI, revs much faster, runs smoother. Opens the door for other performance mods.
Shawn Peterson
1969 Z28, 406SB
http://www.geocities.com/corsican69
Shawn is offline
post #4 of 6 (permalink) Old Aug 28th, 00, 09:53 AM Thread Starter
what about if i have,accel wires.would that run good with the msd ignition,or will hurt the wires.please reply me.
post #5 of 6 (permalink) Old Aug 28th, 00, 10:00 AM
z28lt1350, does a 95 have even have a distributor? I am not sure what year the cut is for 4th gen. If it doesn't, you will have to get one of the MSD DIS boxes. If your car does have a distributor, than go ahead and get the 6AL, if you can. If you ever pop a u-joint or drop a shaft, (or even wheel spin) you will be thankful for the extra $$$ spend on a rev limiter.
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP
**How fast is just a matter of how much $$$ **
Mark W. Winning is offline
post #6 of 6 (permalink) Old Aug 28th, 00, 10:44 AM
Jody
camcojb's Avatar
The 6A or 6AL (w/rev limiter) will both work but you'll need a harness adapter for your coil (part #8877 I think, check with whomever you buy it from). Your Accel wires will work fine as long as they are not solid core and fit your LT1. Gheatly is correct in that you don't need a rev limiter on this car as it has a fuel shut-off just past 6000 rpm (factory rev limiter).
Jody
camcojb is offline
