68 camaro SS or Not?? - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 6th, 99, 08:49 PM Thread Starter
I have a 68 camaro and I am in concern if it is a SS or not ? It is 12 bolt with 5 leafs. Front brake drums are finned. All SS trim in place, Steering wheel SS. Chrome under hood Air cleaner valve covers and fender braces . also car has VIN 124378n416858 the tag on fire wall says 04C 2nd line is 68 12437 nor116888 body 3 rd line is TR 712 RR pnt.Car came with front header and body stripe (hockey stripe). Car also came with shoulder harness in headliner.what do you think?? your help would be greatly appreciated Jerry [email protected]
Jerry Koski is offline
post #2 of 4 (permalink) Old Dec 7th, 99, 12:21 AM
Jerry:
68 Camaros are the most dificult to identify, since the cowl tag has little information, it only tells the type of engine, date built, interior and exterior color.
From the information you posted you can tell its a 2dr sport coupe with a V8 engine built at Norwood, Ohio the third week of April. It has black standar buckets and its original color is Matador Red.
If the rear end is original, a 12 bolt and 5 leafs spring would suggest at least a SS. Take a look at the CRG site, specially at www.camaros.org/diffs68.shtml Also post your car information there.
If you have any of the original documentation, built sheet, Protect-o-plate you will find all the information required.
Hope this helps
Chile
ST-68 12437
ACC.
Moris is offline
post #3 of 4 (permalink) Old Dec 7th, 99, 07:21 AM
Kurt S
Kurt S's Avatar
Original engine or trans?
The #'s off of the rear end will help. See http://www.camaros.org/numbers.shtml#RearAxleNumbers for the location. Post what you find.
Kurt S.
www.camaros.org
Kurt S is offline
post #4 of 4 (permalink) Old Dec 7th, 99, 08:32 AM
If it has a matching number engine via the last digits of the vin on the block would be the best indicator with the suffix with MS for a manual trans or MU as an automatic. Another indicator is that the fuel line is 3/8 not 5/16. The 12 bolt is a good indicator. Here is a site for the codes.
www.camaros.net/years/68/68rearcodes.html
camaroguy is offline
