windshield washer squirter motor - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 25th, 01, 06:03 AM Thread Starter
I have installed all new hoses and nozzels for the windshield washer squirters on my '67. I put in the original washer motor (it has been sitting for about 1 1/2 years) and connected everything. When I hit the button on the dash, everything works, the pump makes noise so it sounds like it's working but no water squirts out. Do I need to prime the motor? Any suggestions? Thanks in advance.
denverRS/SS is offline
post #2 of 4 (permalink) Old Apr 25th, 01, 06:32 AM
Codi's Avatar
You may need to rebuild your pump. It has little valves w/springs in it that can go away. Autozone generally has the rebuild kits cheap and they are easy to do.
Codi is offline
post #3 of 4 (permalink) Old Apr 25th, 01, 08:08 AM
Bret
Try checking the squirters too by removing the hose from each and see if they flow fluid when you hit the button. I bought two aftermarket squirters and one of them was plugged (they had a coating on them like galvanized nails)-had to replace it because it wasn't fixable.
Bret Copsey
'68 Camaro base coupe
'92 Caprice wagon
'98 Malibu
bretcopsey is offline
post #4 of 4 (permalink) Old Apr 25th, 01, 05:14 PM
Gary
After a long time of non use, the pump should be primed. What I have found is a small pin hole can occur when it is used for the first time.
Gary Dorion is offline
