Alt Bracket help - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 22nd, 00, 07:01 PM Thread Starter
I am installing a 454 in my 67 camaro convertable. The motor came out of a 1978 3/4 ton truck( pass engine). I am installing the eldenbrock RPM stuff. My problem is there is no hole in my Moruso long water pump to mount the alt brackets. What do I need to do? Someone must have ran into this problem before... IDEAS?
67rag is offline
post #2 of 4 (permalink) Old Dec 23rd, 00, 05:21 PM
Freddie
Why are you using the long water pump in a '67? They take the short pump. The alternator mounts on the driver's side.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
post #3 of 4 (permalink) Old Dec 24th, 00, 02:48 PM Thread Starter
I figured I would leave the set up the way it was in the 78'. Should I change it to the driver side? What is involved to do that?
67rag is offline
post #4 of 4 (permalink) Old Dec 24th, 00, 03:24 PM
Changing to a drivers side alternator bracket would mean switching to a short water pump and all the assorted brackets and pulleys. Unless you are after the "restored" look I would leave what you have in place. Call Moroso and see if they can help, possibly someone here or Team Chevelle might be able to help. Good luck.
Steve R.
Steve R is offline
