Leakage Problem In Trunk - Team Camaro Tech
post #1 of 4 (permalink) Old May 25th, 00, 10:34 AM Thread Starter
I HAve a 1969 Camaro And MY Trunk Leaks And i Just Put Ne Weather Stripping in.Also MY Back Window Leaks How To Fix
1969Camaro1969 is offline
post #2 of 4 (permalink) Old May 25th, 00, 12:02 PM
You may have small pin hole's around rear window.A quick fix, without having to remove rear window would be, to remove trim and run a bead of window adhesive.Another place you might want to look for leak's, is the seal around your taillight len's.
NOTHING LIKE A 69 !!!!!
Pat's 69's is offline
post #3 of 4 (permalink) Old May 25th, 00, 01:58 PM
Gene
You didn't mention if you have a vinyl top.
Sometimes the pins that hold the vinyl top molding clips down will break off and leave a little hole in the sheetmetal. Water will then run thru the little hole. This is what I found after I stripped the vinyl top off.
Hugger Orange & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 4/5/00 at:
www.geocities.com/gheatly
gheatly is offline
post #4 of 4 (permalink) Old May 25th, 00, 04:15 PM
mccorry's Avatar
For pictures of what the holes look like in the window channel....go to my site and click on the Winter '99 link. This is the same problem you probably have....
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my car ---> www.mindspring.com/~mccorry
mccorry is offline
