GM numbers for frame mounts. - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 25th, 00, 04:27 AM Thread Starter
I'm looking for the correct B/B frame mount GM numbers, drivers and pass. side for a 69 Camaro.
I have some frame mounts but can't find the number in the book. (part # 3945507)
I have the manual but it's only showing the 6-8cly. S/B numbers.
Thanks for a reply, Bob
69 Coupe LeMans-Blue
Frame-Off Resto, ZZ-502/502 Crate, A/C, Griffin Rad., March Serpintine Sys., 2800 Stall with Hughes T-400, Currie 9" with 370 Gears.
http://www.geocities.com/mobiletools1/Mvc-440f.jpg
mobiletools is offline
post #2 of 6 (permalink) Old Dec 25th, 00, 05:10 AM
William
William's Avatar
3945507 & 3945508 are the 1969 302/350 brackets. 1969 396/427 brackets are 3980941 & 3980942.
You will also need the T400 crossmember, 3912573. Still available from GM last I heard.
William is offline
post #3 of 6 (permalink) Old Dec 25th, 00, 05:52 AM Thread Starter
Thumbs up
Thank you William. That was very helpful. The 3945507 I take it is the left side, Drivers.
Bob
[This message has been edited by mobiletools (edited 12-25-2000).]
post #4 of 6 (permalink) Old Dec 26th, 00, 08:56 AM
William, If Mobiletools is using a TH350 trans, shouldn't the trans crossmember be the same as the old motor? Of course, I don't know which trans Mobiletools is using and maybe you do, but I sure hope I'm right on the crossmember cause that's what I'm doing.
Incidently, I bought my frame mounts from Classic Camaros. Everyone else was always out of them.
Toby Keen is offline
post #5 of 6 (permalink) Old Dec 26th, 00, 11:50 AM Thread Starter
I put on the T-400 Trans cross member. The car had a 327 with a power glide. We took out the 327 and put in a little bit bigger motor. I took everything out and off of this car and put back NOS or GM new, or original Z-28 parts(interior items) from a helpful friend in Chicago Ill. He sent me the 69 T-A roof for the car.
Thaks for the help.
Bob
http://www.geocities.com/mobile_tools01/
post #6 of 6 (permalink) Old Dec 26th, 00, 01:35 PM
William
William's Avatar
All small-blocks use the same crossmember regardless of trans; there was no sb/T400 in '69. The T400 piece is quite a bit different due to the length of the trans. Also remember big blocks are offset 1" to the right in the chassis; so is the trans. The manual trans bb crossmember differs slightly in appearance but a sb piece can be modified to fit.
William is offline
