67 engine swap - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 25th, 00, 09:11 AM Thread Starter
trp
need info on installing tpi into 67 camaro.
trp is offline
post #2 of 4 (permalink) Old Dec 26th, 00, 01:59 AM
get the closed loop harness that contains the computer + Sensor plugs and then hook it up. Jeggs or summit sells them
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #3 of 4 (permalink) Old Dec 26th, 00, 11:50 AM
Rather than trying to adapt a factory system, consider an aftermarket system, Holley or Edelbrock perhaps. I've done a Holley system and can't say enough good about it. Everything you need is in the box, and it even comes with instructions (I don't think a boneyard tpi does)You can connect a laptop to it, and tune it real easy.
post #4 of 4 (permalink) Old Dec 26th, 00, 03:01 PM
Check THIS out my friend: www.tpis.com
You got questions? They will help you out.
Tyler
1968 RS/SS Camaro w/ 94 vette LT-1 and T56 six speed, Cal-Tracs, Baer 12" crossdrilled brakes 17" rims, ect....
<A HREF="http://home.earthlink.net/~speedracer68/tyler.htm" TARGET=_blank>
My 68 with LT1 and T56</A>
Teetoe_Jones is offline
