307 Cowl Induction??? - Team Camaro Tech
post #1 of 10 (permalink) Old Dec 27th, 00, 05:58 PM Thread Starter
Exclamation
ive have looked at some pictures of a 307 and its looks to me like it has a cowl inducion air cleaner. and i saw in paddock that they only have cowl induction for a 302, 327 and 350
Inferno is offline
post #2 of 10 (permalink) Old Dec 27th, 00, 06:32 PM
The 307 isn't a .040" over 302 Z-28 engine is it??? (about 307.5 cubic inches) pdq67
post #3 of 10 (permalink) Old Dec 27th, 00, 08:57 PM
Many people have added cowl hoods to their Camaro. Check out how many 67 and 68's have them. Does it say the car was factory equiped with one? My guess is that it was added by the owner unless there is documentation to prove otherwise.
Steve R.
Steve R is offline
post #4 of 10 (permalink) Old Dec 28th, 00, 03:43 AM
The 302 has a 4" bore just like the 350 and 327. That's why they share the same block casting numbers. The 302 just has a shorter stroke at just 3". I don't have my book in front of me but it I recall the 307 has a longer stroke and much smaller bore. I've read that the 307 is not suitable to be bored out to 4" because the casting is too porus that far out...
69 Z/28
www.camarogenerations.com
X77D80 is offline
post #5 of 10 (permalink) Old Dec 28th, 00, 07:01 AM Thread Starter
Does that mean it cant have a cowl induction air cleaner cause thats what i want to know?!?!
Inferno is offline
post #6 of 10 (permalink) Old Dec 28th, 00, 07:21 AM
William
William's Avatar
The "ZL-2 Special Ducted Hood" became available for dealer order around 1 December 1968. As far as is known only ZL-1s #1 & #2 were equipped with it during calendar year 1968. It was available on SS with any engine and Z/28.
If you want one on your car, go right ahead.
William is offline
post #7 of 10 (permalink) Old Dec 28th, 00, 09:48 AM
The height of the intake manifold determines which air cleaner fits, Z-28 type intake fits the one for a 302 , and the cast intake takes the air cleaner for the 350.There is a difference in the metal spacer, 302 shorter for tall intake, 350 a little taller for the shorter intake and no spacer for big blocks.The classic industries catalog explains it.
ClintB is offline
post #8 of 10 (permalink) Old Dec 28th, 00, 03:36 PM
307's came from the factory with 2 barrel carbs. There is no such thing as a factory 2 bbl cowl induction air cleaner.
If the car has a 4 bbl carb then it is not the original carb or intake.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #9 of 10 (permalink) Old Dec 28th, 00, 04:11 PM
Good point Mark C. I forgot about that!! Duh! If you want to stay origianl, don't put one on. If you don't care and like the cowl setup, then do it!
69 Z/28
X77D80 is offline
post #10 of 10 (permalink) Old Dec 28th, 00, 06:18 PM
Talking
I agree, if you like the look and want it on your car then go for it! It is my understanding also that the 307 is basically a stroked 283, and as Mark said they ALL only came with a 2bbl carb. Good Point Mark!
dellerbe is offline
