Power Windows - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 2nd, 00, 01:23 PM Thread Starter
I have an odd question. Is there a difference between the rear power window regulators for a 68 coupe and a 68 convertible? I purchased a complete set of regulators that "supposedly" came out of a 68 and when I tried to install the rear regulators in my convertible I found that the bolt pattern is different.
Any ideas?
68 RS/SS BB Convertible
homepage: http://home.swbell.net/paxtonr
Paxtonr is offline
post #2 of 6 (permalink) Old Jun 11th, 00, 08:46 PM
I have looked in several restoration catalogs and from what I have seen, the parts seem to be all the same, so the only explination I have is that it is from a different year, or maybe a different 68 car.
JMB984 is offline
post #3 of 6 (permalink) Old Jun 12th, 00, 06:53 AM
Most parts catalogs I have don't show any listings for power window regulators, onlt manual.
68 RS, Ash Gold,pwr windows,Hounds tooth
CA420 is offline
post #4 of 6 (permalink) Old Jun 12th, 00, 05:51 PM
The manual and power regulators are different. The manual ones, have the lever gear located higher and so the big toothed arm has its teeth higher.
Conversely since the power window motors basically hang downwards. The drive gear engages the big toothed arm at lower location.
I'm not sure about the other mounting holes, but I have both types stashed in a box somewhere (not for sale), so if you need pictures let me know.
By the way, it's not like you can buy a rear power window regulator anywhere. I have only seen one set on ebay in two years. The good new is the rear regulator rarely wear out. Sure the little nylon roller at the end of the arm breaks frequently. But you can get a car windshield place to rivet in a new one for $.
bonecrusher67conv is offline
post #5 of 6 (permalink) Old Jun 13th, 00, 02:34 PM Thread Starter
Smile
Thanks for the input. I received a couple of emails from other sources that stated that I need to drill 2 new holes for the power regulators and that there are dimples if you look close enough. One is going to send photos with details. Thanks again.
Paxtonr is offline
post #6 of 6 (permalink) Old Jun 15th, 00, 05:33 AM
also remember theres a difference in shaft length fo rthe windows, convertables and deluxe interiors are longer because of the back seat being shorter and the ashtray armrests for the rear, as standar int cars have shorter shafts.
I have deluxe interior (power windows by armstrong ) so my shaft is long.
um, that sounds funny.
Chris's 67 RS can be seen at http://www.geocities.com/macphreak4evr/index.html
JOIN THE CAMARO NET WEBRING! www.geocities.com/macphreak4evr/webring/webringjoin.htm !!!
Chris Edwards is offline
