327 Crank in a 350 Block - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 15th, 00, 01:35 PM Thread Starter
Will a 327 Crank work in a 350 Block and if so what are the benifits or lack of them
REALRS is offline
post #2 of 7 (permalink) Old Feb 15th, 00, 03:51 PM
Bill
Real,
The 327 and the 350 are both 4 inch bore motors. You will have a 327 either way. The 350 Blocks are the same as the 327 blocks. Only differences are the early motors use a small main journal crank aand the later ones a large main crank. 327 crank will still be a327 no matter how you slice it.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 7 (permalink) Old Feb 15th, 00, 03:53 PM
Smile
If you find a large journal 327 crank, Yes it will fit. Benefits? You could build a 4 bolt main 327. These can be made to make some good HP, but not as much torque at lower rpm's as a 350 would be. Alot of people say the 327 was the best small block that Chevrolet built. There are alot of pros and cons, it just all depends on what you intend to do with, or expect out of the engine?
Rick
'68 SS 427
'66 Yenko
YenkoYS100 is offline
post #4 of 7 (permalink) Old Feb 15th, 00, 04:03 PM Thread Starter
Thanks I was asking because I just bought this 68 RS 3 weeks ago. It has a 350 Block #3970010 VO217CUT. With Camel Back Head #3917291 and a 327 Crank #3911001. The Block is bored out 40 over. I am just trying to figure out why the previous owner went this route I like what he did as I can burn rubber up to 3rd gear ( have not tried 4th yet )
REALRS is offline
post #5 of 7 (permalink) Old Feb 15th, 00, 08:51 PM
Cool
cool.
t-tops-ana-4spd is offline
post #6 of 7 (permalink) Old Feb 16th, 00, 11:20 AM
Wink
Its definetly cool!!
Pro Tour RS is offline
post #7 of 7 (permalink) Old Feb 16th, 00, 12:13 PM
Talking
giddieup
shelbyz28 is offline
