12 bolt posi? - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 15th, 00, 05:31 PM Thread Starter
Cool
I have a 1970 camaro with a 12 bolt rearend, how do I know if its a posi?
yru_buggin is offline
post #2 of 5 (permalink) Old Feb 15th, 00, 06:28 PM
Generally when you jack up a car and spin one of the tires the other will spin the same direction. This, however, is not fool proof, if the posi is burned out this will not happen. The only way to know for sure is to remove the cover and look for clutches. If you do remove the cover you can count the teeth on the ring and pinion, plus take the number off the carrier to see if it is a 2,3, or 4 series.
Steve R.
Steve R is offline
post #3 of 5 (permalink) Old Feb 16th, 00, 07:27 AM
Hey steve..You say there is a number to tell if it is a 3 or 4 series carrier...can you please explain?
joeyj is offline
post #4 of 5 (permalink) Old Feb 16th, 00, 10:09 AM
The numbers on the carrier are visible when istalled in the rearend housing. I don't remember exactly where but with a little searching you will find them. These numbers are for Posi carriers only, 2 series ED 32088, 3 series 30140PM1, 4 series EDB30174. I hope this is of some help. Good luck.
Steve R.
Steve R is offline
post #5 of 5 (permalink) Old Feb 17th, 00, 04:18 AM
Wink
Hey..Thanks Steve...Yes it will help lots!!!
joeyj is offline
