rust - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 22nd, 00, 04:09 AM Thread Starter
to dip the car if so were
c shay is offline
post #2 of 5 (permalink) Old Jul 22nd, 00, 05:45 AM
Dont dip it unless you can dip it again in an epoxy bath.
67 Camaro SS Conv.
70 Challenger R/T Conv.
ragtopman is offline
post #3 of 5 (permalink) Old Jul 24th, 00, 05:20 PM
Larry
I plan on dipping my body also. I never heard of an epoxy bath. Could you provide details?
C Shay, There are a few places, one of them called Redi-Strip. I think they are still in business. I bet you could find them with an online search.
Larry
69-er is offline
post #4 of 5 (permalink) Old Jul 25th, 00, 06:16 PM
mwh
Marc
I just got my 69 Z/28 back from Redi-Strip in Evansville, IN. It turned out pretty good and I think it was a good value ($1400). I believe the last part of the process is a bath in some sort of solution that prevents flash rusting, although I don't think it's epoxy based. If you want to see what a car looks like when it comes back, check out:
http://www.staff.uiuc.edu/~mwh/camaro/redi.html
however, be forewarned that I have not trimmed the images down yet, so they will take a while to download.
mwh is offline
post #5 of 5 (permalink) Old Jul 26th, 00, 06:34 PM
The dipping does a good job of removing everything. Thats where I have a problem with it. You can't get to all of those places to seal it up without submurging it (like ragtopman said). We did a truck at work that was dipped and it came back looking great, but the same issue did we get everything coated? (We hope so). The one we did came back with a coating on it like mwh said, but it was just a soap film coating they sprayed on, it had to be removed with water. I have also seen where some acids have found there way back out from nuks and crannies and stained a new paint job.
So if you do it do all you can to neutralize and protect it (water neutralizes most metal etches). just my $.05 worth.
Austin
Austin is offline
