more info on 12 bolt posi - Team Camaro Tech
post #1 of 15 (permalink) Old Feb 17th, 00, 01:19 PM Thread Starter
When I jack up the rear wheels of my camaro I spin one wheel and the other spins, but in the opposite direction. What does that mean?
yru_buggin is offline
post #2 of 15 (permalink) Old Feb 17th, 00, 01:27 PM
Lightbulb
Your posi could be burned out, or you don't have one, i think. Maybe somone can verify this
shelbyz28 is offline
post #3 of 15 (permalink) Old Feb 17th, 00, 01:41 PM
you have positraction ur i come from where we have lots of snow so i know what posi is up here when you get stuck on snow one wheel will turn and the other will not. if you jack up the car you can tell its posi when you spin one wheel the other will spin the other way.
Athorn4941 is offline
post #4 of 15 (permalink) Old Feb 17th, 00, 01:51 PM
Cool
I have a 70 Z with a posi. If you jack the car up and it is in park or gear, you will not be able to turn you wheels. If you can, you do not have positrack. A posi will also put you in the ditch in the winter when you romp on it as well.
67 SS
70 Z/28
camaroguy is offline
post #5 of 15 (permalink) Old Feb 17th, 00, 01:58 PM
no matter what kind of differintial you had you should never be able to move the wheels by hand if in gear or in park
post #6 of 15 (permalink) Old Feb 17th, 00, 01:59 PM Thread Starter
ok, now i'm really confused. one person said the wheels should both spin the same direction with the rear jacked up- and others say they will spin in opposite directions. who's right?
I just bought this car so I'm in the planning($$$) stages right now.
Any help is appreciated.
1970 chevy camaro
post #7 of 15 (permalink) Old Feb 17th, 00, 02:00 PM Thread Starter
ATHORN whats wrong then because I can spin them in park?
post #8 of 15 (permalink) Old Feb 17th, 00, 03:12 PM
If you want to end the confusion, do a burnout and see if you get two black marks!!!
68SS ZZ4, 4sp T-10, 12 bolt, getting painted
78Z28, 330hp vortec, TH350, 10 bolt (just finished)
1st & 2nd GENGuy is offline
post #9 of 15 (permalink) Old Feb 17th, 00, 03:21 PM
Doing a burnout and spinning both tires doesn't necessarily mean you have a posi. When I put the big block in my car with the original 3.08, 8.2, open rear end, if I were to brake torqe the car it would leave a posi mark as far as I desired. I don't know why it did this, I was running just normal radial tires, but I took the rear out anyway in favor for a 8.5, 3.73 posi rear.
68 468 700R4
MarkM is offline
post #10 of 15 (permalink) Old Feb 17th, 00, 03:30 PM
A true posi both wheels should spin the same direction...limited slip will allow one to spin faster than the other when one is under more load than the other. If your wheels spin in opposite directions you dont have a posi...sorry
EMMETT is offline
post #11 of 15 (permalink) Old Feb 17th, 00, 06:22 PM
Cool
Actually, my 12 bolt posi does let the wheels spin in opposite directions when the car is jacked up. I was told that the posi in my car (Eaton, OEM style) will only engage when I am driving the car and the car needs the posi. ???? I can't explain it, I just know it to be true....
Rick
rickmack is offline
post #12 of 15 (permalink) Old Feb 17th, 00, 09:16 PM
Emmett is correct, on a properly functioning posi both tires will spin in the same direction with the car jacked up. But the only way to know for sure it to take the cover off the rear end and look at the carrier.
Steve R.
Steve R is offline
post #13 of 15 (permalink) Old Feb 18th, 00, 06:37 PM
Cool
Sorry guys I jacked up my 89 Iroc 350, my 70 Z/28 and 97 Z/28 and while they are in gear, the wheels will not turn by hand. I put them all in neutral and they turn in the same direction hence they all came with factory posi's.
post #14 of 15 (permalink) Old Feb 19th, 00, 07:40 AM
Freddie
Rear end work is my business (big gear head). A posi that is set up right will cause both wheels to turn the same direction with the trans in N. When the trans is in P you should not be able to turn the wheels. The problem is that when the clutches wear, the unit loosens up and begins to act like a "open" or standard unit. In this case the wheels will turn in oposite directions with the trans in P. The only way to be sure is to remove the cover and look at it. If it has the preload springs, plates and clutches,it's a posi. If it is a posi and it is acting like a standard unit, you need to have the clutches replaced and the preload reset.
big gear head is offline
post #15 of 15 (permalink) Old Feb 19th, 00, 08:41 AM
Exclamation
SETTLED!!
EMMETT is offline
