long water pump on a 68 camaro, is it possible? - Team Camaro Tech
post #1 of 5 (permalink) Old May 10th, 01, 02:03 PM Thread Starter
Can I put a long style water pump off of a 78 camaro on to a 68 camaro that originally had a short style water pump or will it push the fan into the radiator??? I took some measurments and the long water pump would push the fan 1 5/8" closer to the radiator.
1968camaro123 is offline
post #2 of 5 (permalink) Old May 10th, 01, 04:12 PM
Chris
130fe's Avatar
You can put a long style water pump on a 68 Camaro but you have to be sure that you have the long style belt pulleys and brackets (alt, power steering pump, ect.)that go along with it. Just remember if you try to get belts, ask for 69 model stuff (first year of long water pump). It will work if you have all the stuff, just won't be "technically" correct. I assume you are talking about a small block motor? I don't know that much about the big block variety. Hope this helps.
130fe
[This message has been edited by 130fe (edited 05-10-2001).]
130fe is offline
post #3 of 5 (permalink) Old May 10th, 01, 04:28 PM Thread Starter
okay thanks alot
post #4 of 5 (permalink) Old May 10th, 01, 06:40 PM
If it has 68 heads on it you can't do it there is no place to bolt the accessories.
oger is offline
post #5 of 5 (permalink) Old May 11th, 01, 10:08 AM
i used all brackets and pullies from the donor car and had no problems....good luck.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
