69 Camaro wiper motor - Team Camaro Tech
post #1 of 4 (permalink) Old May 11th, 01, 04:08 PM Thread Starter
Can someone tell me what color wires go where on a 69 Camaro wiper motor? Someone cut the plug on my car and I can't seem to get it to work again. Also is there a way to test a wiper motot to see if it works before installing it?
tjones is offline
post #2 of 4 (permalink) Old May 12th, 01, 05:41 AM
Guess
HwyStarJoe's Avatar
Looking at the Service Manual, it shows four wires with a jumper wire....
A Dark Blue on the blade that's away from the other two, a Yellow and a Lite Blue on the center blade, and Black on the third blade. The first and second blades are jumpered with a Yellow between them. All four wires go straight to the fuse block.
Someone with the Wiring Manual will be able to tell you more detailed info on where each wire goes through the fuse block.
Hope this helps!
Joe
WCA Member
[email protected]
'69 wallet crusher
'97 Blazer - Bad wheel hop!
[This message has been edited by HwyStarJoe (edited 05-12-2001).]
HwyStarJoe is offline
post #3 of 4 (permalink) Old May 12th, 01, 06:28 AM
If you can wait until Monday I will fax you the wiring diagram right out of the service manual, but it does confirm what Joe said. Let me know if you have a fax #.
Rdcmro69 is offline
post #4 of 4 (permalink) Old May 12th, 01, 10:37 AM
Bob
tjones:
I emailed you a couple of pictures of the hook up. They aren't the best, but they might help you.
Bob
Garnet Red 69/SS396/TH400/355 Posi
94 HD Dyna Wideglide
phel69 is offline
