Rear axle swap - Team Camaro Tech
post #1 of 14 (permalink) Old Feb 23rd, 00, 02:14 PM Thread Starter
I have a 67 camaro with a 10 bolt non-posi 2.73 rear-end. My ? is, is there any doner car that I can get with a 12 bolt posi 3.73 rear-end with multi-leaf suspention that will bolt on or without difficult mods?
I also want a 700R4 is there a car that I can get both from maybe newer like 88-92?
Thanks in advance for any advice.
Severe 67
Severe is offline
post #2 of 14 (permalink) Old Feb 23rd, 00, 03:24 PM
I believe GM stopped putting 12 bolts in cars in the early seventies.
68SS ZZ4, 4sp T-10, 12 bolt, getting painted
78Z28, 330hp vortec, TH350, 10 bolt (just finished)
1st & 2nd GENGuy is offline
post #3 of 14 (permalink) Old Feb 23rd, 00, 03:25 PM
Freddie
12 bolt rear ends were only made from '65 to '72. The only ones with multi leaf springs that will fit your car are the '68/'69 camaro rears. The '67 camaros all had mono leafs. Can't help you with the 700R4.
big gear head is offline
post #4 of 14 (permalink) Old Feb 23rd, 00, 03:29 PM
what about birds, did they come with 12's
SS396CAMARO is offline
post #5 of 14 (permalink) Old Feb 23rd, 00, 04:05 PM
Talking
i think so, but pontiac was different. I'm pretty sure of this cause my uncle has both
shelbyz28 is offline
post #6 of 14 (permalink) Old Feb 23rd, 00, 05:49 PM
Nova's from 68-70 could come with 12 bolts (SS's inparticular), maybe even 71 or 72. Good luck finding any 12 bolt, they are very hard to find.
Steve R.
Steve R is offline
post #7 of 14 (permalink) Old Feb 24th, 00, 04:58 AM
67-69 camaros,68 through (72-74 10 bolt) novas will fit.I believe the nova rear is a little narrower but only by an 1". Don't quote me on the size.
Ray
8.5"10 bolts ars stronger than people give them credit.
[This message has been edited by BIGBADBOWTIE (edited 02-24-2000).]
BIGBADBOWTIE is offline
post #8 of 14 (permalink) Old Feb 24th, 00, 05:42 AM
don't overlook the late model 8.5" 10 bolts. They're almost as strong as a 12 bolt, plentiful, cheap, and more likely to have posi. Take a tape measure and shop the junkyards. It doesn't cost much to have spring perches welded on, so just look for the correct width.
post #9 of 14 (permalink) Old Feb 24th, 00, 05:42 AM
post #10 of 14 (permalink) Old Feb 24th, 00, 04:31 PM
Freddie
Sorry, forgot about the nova rears.
post #11 of 14 (permalink) Old Feb 25th, 00, 08:21 AM Thread Starter
Thumbs up
Thanks everyone. one more ?. Can I just change the insides of my diff. so that its a posi with 3.73s?
Severe 67
Severe is offline
post #12 of 14 (permalink) Old Feb 25th, 00, 08:39 AM
Yes.
Steve R.
Steve R is offline
post #13 of 14 (permalink) Old Feb 25th, 00, 10:26 AM
I have the same lousy rearend in my 68 camaro. What all would be needed to change the guts to make it a 3:73 posi?
rodsters is offline
post #14 of 14 (permalink) Old Feb 25th, 00, 04:55 PM
You would need to get a posi carrier and the gears you want. I think Eaton and someone else makes carriers. While you are in there you might as well replace all the bearings and seals. The best thing to do would be find a competent rear end shop and discuss with them what you want.
Steve R.
Steve R is offline
