69 RS headlight switch , mech. or elec/mech ? - Team Camaro Tech
post #1 of 4 (permalink) Old May 13th, 01, 04:58 AM Thread Starter
On the 69 RS headlight switches , when you pull it on does it switch the vacuum mechanically or by means of electric over mechanical function ?
I.E.; Can I check out a 69 RS headlight switch by simply applying vacuum (which does nothing as I test it now) , or do you have to have the switch plugged in and powered up to switch the vacuum on and off ?
Thanks !
BH
RSSS69conv is offline
post #2 of 4 (permalink) Old May 13th, 01, 06:53 AM
William
William's Avatar
The vacuum RS switch for 68 & 69 is mechanical. There is 2-port vac fitting on the switch. The fitting is sealed by internal rubber boot contained within a small metal slide. The slide has a lug bent at 90ļ to engage the switch slide mechanism. This lug can break off leaving the system inop.
Someone did a slide repro. They are easily removed. If you have a factory gauge car the h/l switch is different so don't discard it.
William is offline
post #3 of 4 (permalink) Old May 13th, 01, 11:00 AM
mccorry's Avatar
I may be able to help you out...
I have an original RS w/gauges switch that has a broken case. Everthing works on it...but it won't stay together.
Let us know what you find...
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> www.mindspring.com/~mccorry (updated 5/4/01)
mccorry is offline
post #4 of 4 (permalink) Old May 14th, 01, 04:36 AM
Ken
Any idea who makes the slide repro? How different is the switch for gauge vs w/o?
Winch is offline
