Gear Drive, Quiet vs Noisy? - Team Camaro Tech
post #1 of 26 (permalink) Old Jul 31st, 00, 05:13 PM
Rich253
Guest
Posts: n/a
When I look at gear drives in my Summit catalog, It shows two different types of gear drives. Quiet and Noisy.
I know what a Noisy one sounds like, but does anyone know what they mean by "Quiet". Is it as quiet as a conventional timing chain? Or still noisy, just not as loud as the "Noisy" one.
They also say "Minor machining may be required". Does anyone know what they mean by that?
Thanks, Rich
post #2 of 26 (permalink) Old Jul 31st, 00, 05:36 PM
hideaway
Guest
Posts: n/a
rich i had a set in a 33 ford roadster i had and they were the NOISY ones ''pete jackson''.i really liked them in it,but as far as putting them in my 69 no,i like the original look and sound myself in something like that.ok as far as the machining you may or may not have to,on the back of the gears sometimes you have to hit them at the grinder just to give you alittle clearance from the block.quiet ones mean just that QUIET.
post #3 of 26 (permalink) Old Aug 1st, 00, 01:16 AM
Bruce
rich,
from what i've heard, you ought to stay away from gear drives. first off, if one of the gears break, it will jam up everything and could cause some serious engine damage, not like a chain that would just break. second, i've been told they steal away horsepower, because it takes a lot to turn them.
like i said, this is what i've been told by some engine builders and they say to go will a good named double roller or true roller timing set.
later,
bruce
bruce69camaro is offline
post #4 of 26 (permalink) Old Aug 1st, 00, 06:55 AM
I always go for the quietest Pete Jackson or Edelbrock dual idler gear set I can find, the one still in the box, owned by somebody else who will have the problems it will cause.
If I go gear drive, it is always a single idler, fixed to the block. Summers Bros, Milodon, etc.
Jackson, Edelbrock quiet is one with a small amount of backlash between the gearsets, noisy is one that is pre-worn out, loose and both are pure junk, plain and simple. I am sure the ones you are hearing are actually quiet ones, as they make lots of noise.
For street/mild strip use, do yourself a giant favor and use a good double row roller timing set, and stop believing all the racer and high-zoot ad hype.
IgnitionMan is offline
post #5 of 26 (permalink) Old Aug 1st, 00, 08:28 AM
I'm going to go with IgnitionMan on this. I have had friends that used the quiet Pete Jackson drives and it was just still too much. After a month or so they would literally give them away. You gain nothing performance wise using a gear drive over a good double roller. My personal thought on this is if my car is going to sound like it has a blower under the hood then it should. I don't want my car to sound faster than it is. I rather have it sound slow. If I lose to a mustang or something I don't want them thinking they beat a old Camaro with a blower. To each his own but just make sure you can really live with it before you go through the trouble. One more thing, don't install a gear drive on a computer controlled car.
68SS396 is offline
post #6 of 26 (permalink) Old Aug 1st, 00, 09:23 AM
hi
my views on gear drives....waste of money. i bought a camaro with a noisy one and it drove me crazy...tossed it quick. go with a nice quiet double roller chain and you won't be disappointed.
johnm is offline
post #7 of 26 (permalink) Old Aug 1st, 00, 09:34 AM
I think they were cool about 10+ years ago, now there just a little bit "old school". Go with the timing chain.
MarkM is offline
post #8 of 26 (permalink) Old Aug 1st, 00, 12:44 PM
Well,
I've used a Pete Jackson gear drive (quiet one) for years now, and I've had really good luck with it. In fact, I'm putting one in my new race motor, which should run low 10's to high 9's. Say what you want, everyone's entitled to their own opinion, but I think some of you guys are bagging on it pretty hard when it's a pretty good product. Just my 2 cents. Take care.
69 SSRS Frame-off Resto
81 Z-28 377ci Drag Car
69SSRS is offline
post #9 of 26 (permalink) Old Aug 1st, 00, 03:15 PM
See, now, there's words that go together, GEAR DRIVE & RACE ENGINE.
Words that don't are GEAR DRIVE & STREET ENGINE.
Words that don't work, dual-idler-gear-drive, words that do work, single-idler-gear-drive.
Thanks, my opinion and experience.
post #10 of 26 (permalink) Old Aug 1st, 00, 06:12 PM
Wink
What concerns me about gear drive is that it provides a solid mechanical coupling of the crankshaft to the camshaft. This does a much better job of transmitting mechanical resonances to/from the crankshaft and the cam than a chain will. Yes, the end result of this may be difficult to measure, however I guess it makes sense to me to spend less money on a quality chain drive and not worry about adding or amplifying resonances in the engine, especially those marketed as "extra noisy"... I don't think you'll find very many high dollar race engines with that feature.
Just my opinion.
http://www.geocities.com/dmdirks/Automotive.html
RacerX is offline
post #11 of 26 (permalink) Old Aug 1st, 00, 08:16 PM
harmonics is a very large and valid concern with the dual-idler sets, but even more dangerous is the nooisy ones are set with a pair of idler plates that place the gears farther apart. In essence, noisy drive comes pre-worn out, and things just get worse from there as the plates auger the idler gear pin holes farther apart, giving more and more backlash. Over stresses the valve train and doesn't help damping of the cam to crank interface.
Single idler has idler gear pin affixed to the block or an aluminum timing cover, so the backlash doesn't grow with useage.
Double row timing chain doesn't have any of those problems.
post #12 of 26 (permalink) Old Aug 2nd, 00, 12:59 AM
i have a pete jackson quiet geardrive in my camaro. i love it! and it really perked my camaro up. dont know why they get a bad rap.
BLack 69 coupe 350/TH400 factory A/C
MY FIRST 69 is offline
post #13 of 26 (permalink) Old Aug 2nd, 00, 01:04 AM
so a street engine cant be raced now? its got to be a race engine to race.
post #14 of 26 (permalink) Old Aug 2nd, 00, 03:49 AM
You guys that are running gear drives, let me ask you. Why did you decide to go with one? Was it for the sound, more performance? I'm not being a jerk, to each his own, I'm just curious as to why you paid all the extra money for one compared to a roller. The people I know that had them pretty much only bought them for the sound or the hype. Both of which wore out quickly with them. If you run them and like them then great, but why? Teach me something good about them
68SS396 is offline
post #15 of 26 (permalink) Old Aug 3rd, 00, 12:39 AM
i like the sound, i had a 2xroller and i junked it for my geardrive, to me the car acts better, its just neat to hear a car with one, because not to many people use them. i was a cruse and a big block mopar came around the corner with one and i fell in love. just another thing to list on my car, bought one becaue i could. i just like them.
