Stripped Distributor Hold down bolt - Team Camaro Tech
post #1 of 13 (permalink) Old Aug 1st, 00, 07:39 AM Thread Starter
The stinkin' distributor hold down bolt stripped out the threads on my RPM manifold! What a big pain in the rear! I particularly like the way the timing changes while I'm driving.
I suppose there's a heli-coil repair kit and all I have to do is pull the distributor and do the repair? Any body do this already and have any words of wisdom or warnings?
'69 400SB, Richmond 5-speed; '99 HD Road King Classic
www.geocities.com/sdenning1
RockyMtnRacer is offline
post #2 of 13 (permalink) Old Aug 1st, 00, 08:59 AM
I had to do it on one of the Thermostat housing bolts on my RPM manifold. Heli-coils are expensive is all i can say. 20 bucks for a kit that does 2 repairs. Just be patient, read the directions, and make sure the hole is cleanly tapped, you dont want to put the helicoil in only to find out it wont go all the way down, cause it wont come back out.
Ryan67 is offline
post #3 of 13 (permalink) Old Aug 1st, 00, 09:32 AM
Gene
Rock,
You may have to pull the manifold to insure that the new hole you will have to drill and tap is perpendicular to the face of the distributor pad.
I would recommend using an ARP distributor hold down stud. It costs a couple of bucks and you won't have to worry about stripping the threads again.
Couldn't resist - I guess you now have an Edelbroke intake???
[This message has been edited by gheatly (edited 08-01-2000).]
gheatly is offline
post #4 of 13 (permalink) Old Aug 1st, 00, 09:56 AM
You do need to fix it properly but as a quick fix if you need or want to drive it until you do fix it is to stick a piece of wire in the bolt hole then put the bolt in and tighten it. It will take up the extra room of the stripped area and the bolt will be tight. I know its cheesy but it is a decent temporary fix to keep your timing from moving if you have to drive it
68SS396 is offline
post #5 of 13 (permalink) Old Aug 1st, 00, 11:25 AM
NAPA sells some stuff that is designed to "make" threads. It comes in a package with two parts. The first part is like a glue that you pour into the hole and the second part looks like nail polish and you coat the bolt with this and screw it into the hole. Let it set overnight and then remove the bolt. (if you don't coat the bolt, it is supposed to be a permanent part of your manifold). I have not used the stuff, but remember seeing it and it may be worth a shot. The guys at NAPA may have some other suggestions too. Sometimes, just tapping the hole and getting it real clean is enough. Especially in this instance where you don't need to put a lot of torque on the bolt.
denverRS/SS is offline
post #6 of 13 (permalink) Old Aug 1st, 00, 12:20 PM Thread Starter
Good suggestions - thanks! I suppose I could also take the ARP stud and dribble a little JB Weld or other epoxy in the hole and screw it in and let it set overnight.
I can't get too excited about pulling my Edelbroke manifold or spending $20 for a heli-coil. I'll check out the Napa product first and see if that will do the trick.
post #7 of 13 (permalink) Old Aug 1st, 00, 12:43 PM
Carl
It's probably a dumb question, but how about a longer bolt?
Can you drill and tap the hole for a 7/16-14 bolt? The tap drill size is "U" = 0.368". You should be able to do the job with a 3/8" (0.375") drill. I think you could do this with the manifold on but the distributor removed. The drill should follow the original hole close enough for this type of repair as long as you are carefull. You may need a bottom tap to utilize as much of the thread hole as possible.
I just had to drill-tap my swaybar frame bolts because one side ripped out. I upped the size from 5/16"-18 to 3/8"-16 and it worked well. No Helicoils but I had to use a Allen-head internal wrenching screw for clearance.
You may have to file the groove on the hold-down bracket for clearance.
Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc
CarlC is offline
post #8 of 13 (permalink) Old Aug 1st, 00, 02:07 PM
Pull distributor, close off hole.
Use a drill with a stop on it to go to the next thread size, drill.
Use both a starter and bottoming tap of the next size.
Install stepped stud from hardware store, re-install distributor, hold down plate and nut, set timing.
Problem fixed, and the way it should have been, aluminum intake = stud, not bolt.
The least the aluminum has bolts moved through its threads, the linger the threads/aluminum will last and not have problems.
You work with aluminum threads long enough, studs just become the default fastener.
Just what I do for this particular malfunction.
IgnitionMan is offline
post #9 of 13 (permalink) Old Aug 1st, 00, 02:09 PM
I would do what Denver RS/SS suggests. Then I would install a Moroso distributor hold down kit. It comes with a stud and nut rather than a bolt. For the life of me I cannot understand why more people don't use this, I think that using a bolt in that area is ridiculous since it is so easy to strip.
Steve R.
Steve R is offline
post #10 of 13 (permalink) Old Aug 1st, 00, 05:34 PM
Jerry
Rocky, from reading your post your dist was advancing while you were driving, so you over tighten the bolt to hold it in place I had the same problem and I pulled the dist. and installed two gaskets under the dist. I-man has the correct fix for your dist.by the way I was in your town last week it look like a nice town and I loved the mountains!
molaker is offline
post #11 of 13 (permalink) Old Aug 2nd, 00, 08:47 AM
Here's the secret:
Get an AFR Pro-Flo RPM intake. It has 2 holes for the distributor hold downs, it's port matched for the AFR heads you know you're going to break down and buy, and it just may help keep up with the Green (motorless) Meanie.
Shawn Peterson
1969 Z28, 406SB
http://www.geocities.com/corsican69
Shawn is offline
post #12 of 13 (permalink) Old Aug 2nd, 00, 10:30 AM
David Pozzi
davidpozzi's Avatar
IgnitionMan's way will last.
David's Homepage
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #13 of 13 (permalink) Old Aug 3rd, 00, 09:18 AM Thread Starter
I agree - the IM way is the best approach.
Thanks for all the suggestions.
