Power Steering: Do my eyes deceive me? - Team Camaro Tech
post #1 of 10 (permalink) Old Jul 23rd, 01, 10:55 AM Thread Starter
Correct me if I'm wrong, but aren't power steering lines (to and from the pump to the box) supposed to be sealed? On my recently purchased '69 Camaro I noticed that one line has a hose clamp attaching it to the box on one end and another attaching it to the pump on the other. Aren't these lines under pressure? Isn't this a big No-No?
Now, if this is incorrect, how do I fix it? Can I just replace the line?
Thanks!
1969 Camaro - 350...and that's about it for now.
Rabid K-9 is offline
post #2 of 10 (permalink) Old Jul 23rd, 01, 10:59 AM
The hose with the clamps is the low pressure side. Usually a smaller diameter hose.
68 SS 396
camaroguy is offline
post #3 of 10 (permalink) Old Jul 24th, 01, 04:53 AM
i'm pretty sure that both lines on my 68 have fittings on the ends, not clamps. i was wrong. smaller dia. hose has clamps.
[This message has been edited by lola68rag (edited 08-01-2001).]
lola68rag is offline
post #4 of 10 (permalink) Old Jul 24th, 01, 05:18 AM
Charley
That is just the return line. The other line does all the work. It is correct.
clill is offline
post #5 of 10 (permalink) Old Jul 24th, 01, 07:48 AM Thread Starter
Okay, so I guess I'm good then. Now that leaves me with another problem...I've been finding small pussles of orangish fluid under my car from time to time. I originally thought it was the previously mentioned power steering lines (especially since it seems to be wet around that area). Now I don't know what it is. Any clues before I go searching?
post #6 of 10 (permalink) Old Jul 24th, 01, 08:19 AM
Robert
The high pressure line may be leaking. That isn't uncommon at all. As a matter of fact, mine was leaking when I bought the car. If you determine it is leaking take it with you to the parts store, as I had trouble matching mine up. Things get changed over the years.
Robert
'69 getting better every day... (every pay day)
rojo is offline
post #7 of 10 (permalink) Old Jul 24th, 01, 09:47 AM
Gary
Most of the power steering hoses I found at the parts stores were rough textured, wrapped construction. I finally got a "nearly correct" smooth hose from NAPA (had to be special ordered) I say nearly correct, because the pressure line into the steering box is somewhat taller than the original. Also, the return hose had a pinch clamp, rather than the screw type clamp. My original was screw type, but Rick's sells both, so I assumed either would be correct. You know what they say about assumptions!
Unreal is offline
post #8 of 10 (permalink) Old Jul 25th, 01, 10:36 AM
JohnZ's Avatar
On your leak - what color is the coolant in your radiator? The new "Dexcool" coolants are orangish-colored - could be a coolant leak. If your coolant is the usual green, then it's something else, most likely power steering fluid.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #9 of 10 (permalink) Old Jul 25th, 01, 11:06 AM Thread Starter
Nope. My anti-freeze is green.
Could it be something else? Maybe where ever the fluid is escaping from is rusty. But, where. I need to jack this puppy up and take a look at it.
post #10 of 10 (permalink) Old Jul 26th, 01, 04:22 PM
Bob
Shoot the cat.
Bob
Garnet Red 69/SS396/TH400/355 Posi
94 HD Dyna Wideglide
phel69 is offline
