305 won't turn over - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 1st, 01, 03:41 PM Thread Starter
OK camaro experts. I have an 84 Camaro with a early 80's 305. Has stock aluminum Intake. I just put on a new Q-jet carb. After i installed that I only had it fired up about 6 times. Now the damn thing barely turns over. I don't know what to do. I'm not sure about the timming but sometimes I can go out and it'll turn over good and not start and others it just won't turn over at all. PLEASE HELP
1984 Camaro is offline
post #2 of 9 (permalink) Old Apr 1st, 01, 05:15 PM
Check you grounds including the battery post and make shure your battery has a good charge.
6-71BlownCamaro is offline
post #3 of 9 (permalink) Old Apr 1st, 01, 05:43 PM
Lightbulb
just a suggestion check your battery to see if there is enough amperage from the battery it is an easy check just put a mulitmeter on your battery post and have some one start the engine if you voltage drops way down then you could have a bad battery
StanA is offline
post #4 of 9 (permalink) Old Apr 2nd, 01, 01:00 AM Thread Starter
Ok, i'll try those things when I get home today from work. I have my moms car for the time being. I had a slow battery charrger on it all night, and I got out and it turned over real good. Just won't fire.
Ray
post #5 of 9 (permalink) Old Apr 2nd, 01, 08:17 AM Thread Starter
ok i got a really good explanation of what my car is doing when I try to start it. I got the battery good and charged up. I stuck a volt gauge to it and when I turn it over it jumps down between 10-11 normal right? But when I go to give it some gas it bearly wants to turn over. Like the battery is dead. When it was cranking hard the gauge stayed at 10-11. What's the problem>????
Ray
post #6 of 9 (permalink) Old Apr 2nd, 01, 08:38 AM
try cleaning your plugs & charge or buy new battery, clean battery cables.
good luck. joe
joe hansen is offline
post #7 of 9 (permalink) Old Apr 2nd, 01, 08:52 AM Thread Starter
I just added new plugs and the batter is brand new about 3 months ago. It's one of those big interstate battery's. So when I'm cranking it over and the gauge reads between 10-11 it's no good? Why does it crank hard when I pump the gas?
RaY
post #8 of 9 (permalink) Old Apr 2nd, 01, 10:21 AM
Cool
Sounds like timing is advanced alittle too much. 10-11 volts is fine for the battery reading while cranking.
Once you get it running, measure charging voltage at the battery, s/b 13.5-14.5 volts.
May have to tighten drive belt, you said it cranked over fine for about six times then died.
post #9 of 9 (permalink) Old Apr 13th, 01, 05:54 PM
Thumbs up
I agree with everett that it might be your timing it sound like your battery is really good good luck.StanA
StanA is offline
