10.4 or 11" bellhousing and clutch - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 1st, 01, 08:35 PM Thread Starter
I currently have a 10.4 inch clutch and bellhousing in my 67 that was originly in a 6 banger. now a 350.
What signifigance would there be to place a 11 inch clutch and housing in it?
Is it stronger or offer better performance?
I am removing my saginaw and placing in a munci m-20.
Also Will i need to change the flywheel?
67 Camaro
84 Z28
89 Camaro
http://members.ebay.com/aboutme/[email protected]
dragon0123 is offline
post #2 of 2 (permalink) Old Apr 2nd, 01, 04:29 AM
Jody
camcojb's Avatar
I'd recommend a 10 1/2" Centerforce dual-friction clutch set-up. They handle a bunch of power and are easy on the leg. They also bolt right in with your stock flywheel and bellhousing.
If you must have an 11" clutch, McLeod makes an 11" pressure plate and disc set-up that fits the 10 1/2" bolt pattern flywheel.
If you do switch to a standard 11" clutch, you'll need a new flywheel, bellhousing, and starter (or at least change the nose housing).
Jody
camcojb is offline
