69 Power Steering Pump Adjustment bracket??? - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 4th, 00, 02:07 PM Thread Starter
BUD
Installing a 400 sb with power steering in 69. I am using headers, what is the best adjustment bracket to use with pump when using headers? The piece I have for the cast iron manifolds doesn't seem to work with headers.
BUD is offline
post #2 of 2 (permalink) Old Dec 4th, 00, 02:54 PM
Gene
BUD,
Your headers should have come with a spacer for the P/S bracket. It is basically a small piepce of "pipe" cut to the proper length and placed between the header mounting plate and the bP/S bracket. You will need a longer bolt to go thru the bracket, "pipe", and header mount into the head. I used my stock manifold bolt and it worked fine.
Pearl blue & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 11/29/00 at:
www.geocities.com/gheatly
gheatly is offline
