Cal-Tracs & Spring Relocators? - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 24th, 01, 04:15 PM Thread Starter
Can I use both the Comp Engeneering kit to relocate the shocks and Cal-Tracs without having one of them interfere with the other? I want to make sure of this before I buy them. Will any special fabrication be needed?
Kyle
KiZile is offline
post #2 of 8 (permalink) Old Jul 25th, 01, 02:40 AM
The Cal Tracs come with there own shock mounts welded to the bottom spring retaining plate.Why do you need to move your shock location? I have Competion Eng frame connectors and Cal Tracs but left shocks in stock location on my second gen.
Brian.
asumtoy540 is offline
post #3 of 8 (permalink) Old Jul 25th, 01, 03:10 AM
Does Cal Tracs have a web site? I can't find it.
Thanks,
Rob
RFrenette is offline
post #4 of 8 (permalink) Old Jul 25th, 01, 03:28 AM
AL
302XRAM is offline
post #5 of 8 (permalink) Old Jul 25th, 01, 04:22 AM
Tony
Talking
Kyle,
YES!! I have the Competion Engineering SHOCK relocation mount and I just bought a set of CAL-TRACS for my 67. I just told them that I want the lower shock mounts to be in the back and inside of the axle houseing, I also have C/E's subframe connecters.
I have not installed the Cal-tracs yet because I am going to do some track testing and comparisons.
TONY
67 CAMARO R/S CLONE, 355/turbo 350, 200hp NOS,12 bolt,etc...
idoxlr8 is offline
post #6 of 8 (permalink) Old Jul 25th, 01, 04:40 AM
Not to get off topic, but what do you guys think of the cal-tracs? I was thinking of dumping my slappers for a set, but I am already pulling 1.53 60 foots. I am building a bigger motor, so I figured traction would again become a problem.
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.79 @ 123.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Member of the "unwanted" 3rd Gen group.
Mark W. Winning is offline
post #7 of 8 (permalink) Old Jul 25th, 01, 01:22 PM
is their website the only place you can buy them or does summit or jegs carry the cal trac bars.
fro-fro is offline
post #8 of 8 (permalink) Old Jul 25th, 01, 02:22 PM
Tony
Thumbs up
Mark,
I am going to find out which ones have a performance advantage as soon as I get my new motor into the car. My current set up is C/E "J" bolt traction bars with monroe basic replacement shocks, 5 leaf (one removed now 4) springs, and C/E sub-frame connectors. With this set-up the car would pull the left front 4-6 inches and carry it for about 40-60 feet. weight transfer to the rear tires is awsome as the car squats 8 inches in the rear. The car never made a full pass with this set up as I kept having other drive train problems (broken axle,trans and twisted a drive shaft on different passes).
I am going to track test this set up and then switch to Cal-tracs and Hal adjustable shocks and see what happens.
I hope to have this done by October but we have to wait and see.
TONY
idoxlr8 is offline
