Left Exhaust Reinforcement on 69 - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 25th, 01, 03:47 AM Thread Starter
Gary
My 69 was a single exhaust, and if I remember correctly, the pass side has weld nuts welded inside the frame, and was not reinforced.
I used well nuts, to install my driver side exhaust. If I remember correctly, there were two small holes in the frame, which I enlarged to fit the well nuts. Now I'm beginning to question the sanity of going that route. I'm thinking I should duplicate the reinforcement plate, and install it in place of the well nuts.
Was the driver side reinforcemnet plate tapped and threaded, or maybe have weld nuts welded to the inside of the reinforcement? If weld nuts, Were the small holes in the frame, pilot holes which would be enlarged to accomodate the weld nuts? What are the dimensions and guage of the reinforcement. Should the reinforecment plate be tack welded, or continuous. I know that's a lot of questions; thanks for the response.
Unreal is offline
post #2 of 5 (permalink) Old Jul 25th, 01, 04:02 AM
Call up Larry Christiansen at Camaros Plus in Colorado (303)420-6229. Last I knew, he had these reinforcement plates all made to correct specs. I don't know how much he gets for them. He is also very knowageable about how these cars went together, I'm sure he could answer any of your questions about exact assembly.
kurt6325 is offline
post #3 of 5 (permalink) Old Jul 25th, 01, 05:48 AM
Gene
Unreal,
Please let us know the details of your call with Larry if you do call him. This is a part seeveral of us could use. Thanks
gheatly is offline
post #4 of 5 (permalink) Old Jul 26th, 01, 03:43 AM Thread Starter
Gary
Will do...I tried calling him yesterday; he wasn't in, and the guy I talked to couldn't help. I'll try again today, and report back.
Unreal is offline
post #5 of 5 (permalink) Old Jul 26th, 01, 11:26 AM Thread Starter
Gary
Well, I called. They are drilled and tapped. They're $35 plus ship. Seems high to me, considering I can make one for nothing.
Unreal is offline
