Info on 6 speeds in a 68 Camaro - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 25th, 01, 09:33 AM Thread Starter
Hey Guys, I just bought a 68 SS and I am building it into a Pro Touring Machine. I see alot of T-56's and Richmond 6 speeds in 67-68-69's out there and I'd like to know what Is involved in installation. oh..just to let you know, theres a 383 stroker with a ProCharger on the engine stand itching to make its way into the new project =)
Jason
ProTouring68SS is offline
post #2 of 8 (permalink) Old Jul 26th, 01, 08:08 AM
Exclamation
Either way is a very viable option.
Several have done the hydraulic T-56,and several (me included) have done the Richmond.
In both cases you will need some crossmember work, driveshaft work, and in the case of the Richmond, tranny-tunnel modification where the shifter comes through.
Hopefully Teetoe-Jones will see this. He has a bracet kit for ease of installation when doing the T-56 install.
67LT1 is offline
post #3 of 8 (permalink) Old Jul 26th, 01, 09:09 AM
and lest we not forget the speedometer issue.. It will cost you some additional money and down time to make your stock speedo work with the T56. $295 + shipping + handling + insurance to send your tailshaft out to get it modified to drive a cable-and then a minimum two week turn around time. Or, go simple and switch to an electronic speedo. Cross member fabrication-or modify your existing one.
Go69 is offline
post #4 of 8 (permalink) Old Jul 26th, 01, 09:11 AM Thread Starter
Ok, Thanks Guys,
post #5 of 8 (permalink) Old Jul 26th, 01, 09:46 PM
The Richmond is the easiest, its just like a five speed which is like a four speed, t56 uses some weird bellhousing, uses a hydraulic throwout bearing all kinds of conversions, the richmond is expensive but worth it much more straight forward and simple and a better tranny and you can pick your gear ratio
cody is offline
post #6 of 8 (permalink) Old Jul 27th, 01, 07:58 AM
I agree with Cody about the Richmond being a better choice-if you have the money! You can get the T56, with bellhousing, comlete hydraulic clutch assy., clutch, pressure plate and shifter for around $1k at most any junk yard. Then with some fab work you can be in business. I think that for most DIY'ers the T56 is very easily accomplished. However if I had the money to throw around, i would have gone the Richmond route.
Go69 is offline
post #7 of 8 (permalink) Old Jul 28th, 01, 04:23 PM
ZZ_430's Avatar
I really like the Richmond 6 in my 67. As stated earlier, it is much easier to work with than the T-56, not to mention it's much stronger....have pic>> http://www.members.aol.com/zz430drop.../img_0022.jpg/ I will be glad to answer any questions...
zz430droptop67rs
Pro-Touring.com My Page
67 RS/SS Convertible, 70 RS/Z28
[This message has been edited by ZZ430DropTop67RS (edited 07-28-2001).]
ZZ_430 is offline
post #8 of 8 (permalink) Old Jul 28th, 01, 04:47 PM
Charley
There is a Richmond 6 speed listed for sale in the Classifieds section of this Web site.
clill is offline
