wiring from floor shifter question - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 26th, 01, 09:59 AM Thread Starter
I have a 67 floor shift car. Which way do the wires that come off of the neutral safety switch go back to the fuse box. My wireing was missing. does it go down the tranmission channel or does it go back up and under the carpet?
thanks
Crichton Minges
[email protected]
cmmphish is offline
post #2 of 2 (permalink) Old Jul 26th, 01, 10:22 AM
The wires go back to the fuse block. The two purple ones are the neutral saftey switch the pink and the green are the backup lights. The shifter has a short wire lead with connector. There is a wire harness that will take it back into the underdash wiring and up to the dash keyed switch. Check out one of the aftermarket parts guys, Ground Up, Ricks, Year One. They all sell a "Painless Wiring" harness.
The wiring in my 67 does not go under the carpet. It is clipped to the underside of the console and runs toward the firewall.
If you need any pics of this let me know by email [email protected]. As you might have seen from some of the postings today, I have a Neutral saftey switch issue I am dealing with and have this part of my car including the wiring exposed.
Good luck with yours.
'67 SS Convertible Camaro 402BB, TH400, 3:73 12 Bolt Posi [email protected]
Pennsylvania
Picture Link: http://www.geocities.com/jjknotts/1967Camaro.html
jknotts is offline
