help.....M20 or M21 - Team Camaro Tech
post #1 of 10 (permalink) Old Jun 4th, 01, 06:03 PM Thread Starter
well can any one help me make up my mind? any input.i heard that the M21 is not to good off the line when using 331 gears..as where the M20 is better using the same gears...oh, and any one here selling one? thanx,david
69 z-11 is offline
post #2 of 10 (permalink) Old Jun 4th, 01, 06:15 PM
Use the M20 with that tall a rear end. the M21-22 will be terrible to drive. If you don't have a trans now think about a ST10 they are much cheaper and have much better gear ratios.
oger is offline
post #3 of 10 (permalink) Old Jun 4th, 01, 06:25 PM
stevo camaro's Avatar
It's because the 1st 2nd & 3rd gear ratios are different. A M-20 has a 2.52:1 1st. A 1.88:1 2nd and a 1.46:1 3rd. 4th is direct.
Both the M-21 & M-22 have a 2.20:1 1st. A 1.64:1 2nd and a 1.28:1 3rd. 4th is direct.
I have 3:08's. I would rather have the M-20 with those gears because they are lower, which I need to get going with tall gears.
If I had lower gears, like 3:73's or 4:11's I would want the M-21, or better yet, the M-22, just because it has better gears. They have a taller ratio.
Any of this make sense? I hope so. Alot depends on your tire hieght also. This is general, alot has to do with how the car is setup.
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
stevo camaro is offline
post #4 of 10 (permalink) Old Jun 4th, 01, 06:29 PM
69 z-11
With your gearing you are going to be much better off with a M20. The lower first gear is going to make for much better off the line grunt and drivability. Also I have an extra M20 in the garage, E-mail me if interested. Also if anyone is interested I have a near new 11" centerforce duel friction clutch and pressure plate as well.
Good luck
Thomas (AKA Hot66ss)
66 Super Sport Now striped frame off Project
67 Malibu Getting there.
69 El camino Beater Mild 355, M21 4 speed (Daily Driver)
Video of me in the Elco smoking the tires
Aces Member 2380
Team Chevelle member #262
Hot66ss is offline
post #5 of 10 (permalink) Old Jun 4th, 01, 07:15 PM Thread Starter
wow.thanx for the reply.i do understand now...so i will be looking for a M20...sure happy with all the "FAST" response.you guys are great...good night,david
1969 z11 pace car.396/350 hp..1997 30th convertible brickyard pace car no.1-1965 chevelle malibu,1969 camaro s.s. [email protected]
69 z-11 is offline
post #6 of 10 (permalink) Old Jun 5th, 01, 03:20 AM
Jeff
The M21 and M22 are close ratio transmissions so the gearing is closer together and will result in less rpm drop between shifts. If you're gonna race the car, then the M21 or M22 is the ticket, but for driving the M20 is better.
Jeff H - 93 Indy 500 Pace Car(supercharged), Hugger Orange 69 Z28 with JL8 brakes, cross-ram & GM fiberglass hood, being restored
Jeff H is offline
post #7 of 10 (permalink) Old Jun 5th, 01, 12:41 PM
Kurt S
Kurt S's Avatar
1 correction, Jeff.
M21/M22 only has less rpm drop between 3-4. The percentage drops on the other 2 shifts are the same as a M20.
Kurt S.
CRG www.camaros.org
Kurt S is offline
post #8 of 10 (permalink) Old Jun 5th, 01, 05:48 PM Thread Starter
well, i just found the code # on the rear end and it isn't a 3.31..... but it is a BP code....=2.73...darn...
69 z-11 is offline
post #9 of 10 (permalink) Old Jun 6th, 01, 07:47 AM
cant find a m20, stuff m20 input shaft,gears,and counter shaft into your m21 case, I just did my 67 pace car, got every thing i needed from national drive train.
Ron Moss is offline
post #10 of 10 (permalink) Old Jun 6th, 01, 07:17 PM Thread Starter
great response guyz.....but my wife just aproved 20 grand more for a "4-speed car"..so i just sold my sport coupe tonight and am looking for a-- s.s. or z28...with a 4 speed..thanx again,david
69 z-11 is offline
