Carb suggestions - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 4th, 01, 05:24 AM Thread Starter
79Z
Greetings all!
I've just recently completed a 350 with vortec heads and comp 268 cam, performer intake. Sitting on top of this is a qjet from a mid 70's truck.
Now it drives alright under slight to mild throttle, any more and it will stumble. I can't give it wot, it gets upset with me.
I know I'm lean, and my carb needs some tuning, probably bigger jets. I've tried tightening the secondary air flaps, minor help.
I want to take the carb off to convert it to electric choke. While I'm at it, I want to know what you think I should do for jets, metering rods, and other components before I go buy peices to rebuild it.
Any advice or recomendations appreciated.
One odd note. the car runs best with the screws all the way IN. I know this isn't common, most people I know with 2nd gens need to turn them out 3 or 4 times...
79Z is offline
post #2 of 8 (permalink) Old Apr 4th, 01, 07:57 AM
Lightbulb
Try droping in a set of stiffer step up springs and reset your carb to the highest vacuum. I bet you'll lose your stumble. If you have the cash, get a holley 750cfm.
goatjj is offline
post #3 of 8 (permalink) Old Apr 4th, 01, 09:53 AM
I have a 750 edelbrock #1407 that worked out great for me but I had a little more cam etc. you may want to try a 650 cfm model.
Not to offend anyone I have holleys on my blower motor that work pretty good .But I dont think holley carbs are that great. I have really liked my edelbrock carbs in the past and for my blower Im going to switch to predator carbs.
just my opinion but holleys need too much attention.
6-71BlownCamaro is offline
post #4 of 8 (permalink) Old Apr 4th, 01, 09:56 AM Thread Starter
79Z
I'm sticking with quadrajet. It just needs to be tuned in. Was looking for recomendations on that.
79Z is offline
post #5 of 8 (permalink) Old Apr 4th, 01, 01:10 PM
Well, it's your call, but I just went through the same problem with my old QJ. I priced out a rebuild on the QJ to a new Holley in the box, and the dollar figure was about the same, so I just bought a new one, with warranty and the whole works.
BreathWeapon is offline
post #6 of 8 (permalink) Old Apr 4th, 01, 06:09 PM
Not sure about how good they are but edelbrock makes some performer series Q jets.
post #7 of 8 (permalink) Old Apr 4th, 01, 06:57 PM
Well. Im no expert but I have a lot of experiance with QJets, First they are an extreamly Under appreciated Carb, However when they are swapped off one motor and put on the next they are very problematic, first off before you try ANY modifications, Rebuild the carb, Blow all the pasagges out of the carb expecially where the idle mixture screws thred in, when that is done first off thred the screws out 2- 1/2 to 3 turns and start the car, set the Ignition timing and hook up a good tach to the engine one that will show even a 10 to 20 rpm diference then thred out the drivers idle screw until you achieve maximum RPM then do the same with the passenger once they are both set adjust the idle speed screw on the carb the the correct RPM (bout 1000 or so in park.) Then and only then you should begin playing with the secondary Meetering Rods Then save yourself a ton of hassle and Call Jet Performance (Their ad is in most Hot rod Magazines) and tell them your application they will give you advice on what metering rods to run and which hanger to run, since GM made about 50 different rod/hanger combo's. if you need anymore info feel free to E-mail me.
mbonazzo is offline
post #8 of 8 (permalink) Old Apr 4th, 01, 07:06 PM
Also just FYI Gm Truck Quadrajets are Notoriously high CFM,, a 454 QJet is 800CFM, This may also be a bit much for your aplication not knowing the casting # I cant tell you the CFM but if you get me it Ill try and ID it for you it should be on the drivers side on the side of the main body printed verticaly. This is the same number you use to order the rebuild Kit. just a sudgestion speeking from experiance take the secondary metering rods out first and carfully lift them out this will save you many hassles trust me also with the accelerator pump arm use a small nail to push out the piviot pin and remove the arm do not try to take the carb top off and wrestle the rod out of the arm, youll break it trust me I speek from experiance.
mbonazzo is offline
