What headers to use? - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 5th, 00, 04:19 AM Thread Starter
I'm in the process of building a small block 350 for a 76' camaro. I've not been able to get a clear answer on what type of headers to use. Will I need shortys for ground clearance or can I use standard?
termigator is offline
post #2 of 10 (permalink) Old Apr 5th, 00, 01:21 PM
Ground clearance should not be a factor if you are running with stock springs. I run Flow Tech headers on my 75 with no problems.
Hope this helps.
lowecw is offline
post #3 of 10 (permalink) Old Apr 5th, 00, 01:44 PM
Opinions on headers are like a$$ holes, everybody has one. It seems like everybody has a favorite, so as you receive opinions on which is best, just remember this: Pretty much ANY header is light years ahead of stock manifolds. As lowecw pointed out, if it's not lowered, OR more than an inch or two, clearance should be fine. If you are dropping the car more than that, you may consider shorty's or a tri-y which are also very effective.
Shawn Peterson
1969 Z28, 406SB
http://www.geocities.com/corsican69
Shawn is offline
post #4 of 10 (permalink) Old Apr 6th, 00, 02:46 AM
Cool
Either header will do fine for ya but for practical reasons take in account the road conditions in the area that you live in. Speaking from experience it matters as I grew up in a small area with not so good roads and streets and wished I had a pair of shortee's. LOL! Just a bit of .02 cents worth. With that you be the judge.
71 Camairo
71 Camairo is offline
post #5 of 10 (permalink) Old Apr 6th, 00, 06:34 AM Thread Starter
Thanks for input. I'm sure I'll be back with more questions in the future.
post #6 of 10 (permalink) Old Apr 6th, 00, 06:00 PM
stevo camaro's Avatar
I like Shawn's answer.
stevo camaro is offline
post #7 of 10 (permalink) Old Apr 6th, 00, 06:13 PM
post #8 of 10 (permalink) Old Apr 7th, 00, 05:09 AM
Lonnie
Regular long tube headers will work fine. If you buy $90 Hookers or Dynomax and do smash em. its better than smashing $350 headers.
67 410sb 11.76 @116.6
Lonnie67 is offline
post #9 of 10 (permalink) Old Apr 7th, 00, 12:01 PM
I'm thinking about the Hedman shortys. will these work with a small block and 4 speed in a 69. Any experience with these? I'd like to hook them to a chambered system.
jacksz28 is offline
post #10 of 10 (permalink) Old Apr 8th, 00, 07:49 PM
Has anyone heard anything about the flowtech,
after burner headers? from the article they sound pretty good.
Severe 67
Severe is offline
