350 3 speed bellhousing, please help!! - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 5th, 01, 04:00 PM Thread Starter
Exclamation
I recently had to pull my 327 out of my 68 camaro. The block was too badly damaged to use so I switched to a 350 block but the flywheel wont fit in my saginaw 3 speed bellhousing. Can anyone suggest a place to find a 350 bellousing (bottom portion cut off ) or anything else to remedy this situation?
spam4u is offline
post #2 of 2 (permalink) Old Jun 6th, 01, 04:15 AM
Gene
If you can't find a bellhousing, the other option is to switch to a 10.5 inch flywheel. The 350 probably has a 11 inch flywheel. The 10.5 is fine, its what they put behid the 302.
gheatly is offline
