411 posi rear - Team Camaro Tech
post #1 of 17 (permalink) Old Apr 4th, 01, 04:32 PM Thread Starter
Does anyone know if 411 posi rear is original on a 69 camaro?
biggie is offline
post #2 of 17 (permalink) Old Apr 4th, 01, 04:36 PM
Freddie
Yes, it was an option.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
post #3 of 17 (permalink) Old Apr 4th, 01, 04:47 PM Thread Starter
I found a 69 camaro the guy said it has the original engine 396/375hp with 411 posi rear. Needs paint and interior work he is asking $5000 is this a good deal?
biggie is offline
post #4 of 17 (permalink) Old Apr 4th, 01, 05:11 PM
Well maybe.However a 375 hp big block wouldn't really need 411 gears.Something around 342's would be better.Someone will correct me if I'm wrong I'm sure. 373/410/411 were good for small block cars z/28's.The tourqe of a big block didn't need that much gear because they didn't wind up that tight.
70 z/28 4sp,71 camaro hugger orange/white stripes,2000 v8 Grand cherokee.(Former Know it All)
zgator is offline
post #5 of 17 (permalink) Old Apr 4th, 01, 05:15 PM
In stock form a 375hp will run to 7000 very easily.
oger is offline
post #6 of 17 (permalink) Old Apr 5th, 01, 04:48 AM
Sorry to piggyback, but what is the difference between 4:11 and 4:10? I heard that 4:10 was a 12 bolt rear and a 4:11 was a 10 bolt. But weren't all SS cars (396/375 HP cars) come with a 12 bolt? This would indicate the car being discusssed in this thread would have to be a 4:10.
The guy I bought my Z from indicated it was a 4:11 but it had a 12 bolt rear so I have been calling it a 4:10
R. Stacho (a.k.a. Mytmouse)
67 SS 396 Chevelle 350HP 4speed
70 SS 396 Chevelle 350HP 4speed
68 RS Z/28 302 350+HP? 4speed
Robert Stacho is offline
post #7 of 17 (permalink) Old Apr 5th, 01, 05:15 AM
I have 8.5" 10 bolt in my 56. It came off a drag car. Anyway, it's a 1971 10 bolt and it has 4.10. I counted the teeth/gears myself.--but then, I don't know about the 8.2" 10-bolts.
tufz is offline
post #8 of 17 (permalink) Old Apr 5th, 01, 06:08 AM
Cool
Difference is dependent upon manufacturer of gear set.
4.10 = pinion 10, ring 41 teeth
4.11 = pinion 9, ring 37
The bigger the pinion, the longer the level.
post #9 of 17 (permalink) Old Apr 5th, 01, 06:24 AM
Everett & Others
Thanks for clearing that up for me
Robert Stacho (a.k.a. Mytmouse)
post #10 of 17 (permalink) Old Apr 5th, 01, 07:29 AM
411 is not too low for that motor. the all aluminum 427/430hp copo camaros were offered with only 410 or 456 rear ends. chevrolet would not have done this if they were too low.
lloyd is offline
post #11 of 17 (permalink) Old Apr 5th, 01, 09:31 AM
I want that car! Can I have it? Do you live near me?
Chris Davis is offline
post #12 of 17 (permalink) Old Apr 5th, 01, 09:53 AM
Can you put 3.73, posi gears in a chicken-leggin', 8.2", 2.73, 10 bolt?
(The car is a 69 Camaro. Orig had a 6 cyl - hence the 2.73, 10 bolt.)
RFrenette is offline
post #13 of 17 (permalink) Old Apr 5th, 01, 04:03 PM
Freddie
RFrenette,
Yes you can put 3.73s and a posi in a 8.2. Torq-Line makes a posi unit for it and several manifacturers make the gears.
427/4spd/9"
post #14 of 17 (permalink) Old Apr 5th, 01, 04:36 PM Thread Starter
Well I talked to the guy again he checked the cowl tag and its a X44 car so it cant be original big block camaro. So I decided not to buy it.
biggie is offline
post #15 of 17 (permalink) Old Apr 5th, 01, 04:48 PM
You should always check the VIN against the cowl tag. Alot of camaros had a v8 cowl tag (12437) and a straigt 6 on the vin. If it has a 12337 on the vin, its a 6.
69er
69 Camaro 454
71 Nova 454
If your not living on the edge then your taking up too much space
69er is offline
