Rod to Throttle Cable Converstion Help - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 5th, 00, 05:16 AM Thread Starter
i want to change from my throttle rod linkage on my 69 Camaro to a throttle cable setup. Is this hard to do? Which cable works? Will a stock 70 model cable work? Any help is appreciated!!!
johnm is offline
post #2 of 2 (permalink) Old Apr 5th, 00, 06:24 AM
Bruce
john,
my 1969 camaro came through with a six cylinder, and that had a cable throttle. the only problem i had when i went from six cylinder to big block, was with the bracket to hold the cable to the intake. i didn't like how it was, so i converted to rod linkage. so you may want to look into going with a six cylinder gas pedal assembly and try to find a newer throttle cable that is long enough to open up the carb the whole way.
good luck,
bruce
bruce69camaro is offline
