69 Big block project - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 28th, 01, 05:27 PM Thread Starter
Talking
I'm starting a small to big block conversion to my 69 camaro. I know I'll have to change springs and heater core, but what other things am i going to run into bolting it down in the car. Will the BB bolt to the small block stands and work. I'm also converting the previous TH350 to an M-21 muncie that the car originally came out with. What kind of Trans crossmember problems will I have. It would be a lot easier to know this than to swing that bad boy off in there and go UH-OH two or three times before it's right. Thanks for any help!
Bedanobub is offline
post #2 of 4 (permalink) Old Jul 28th, 01, 05:39 PM
You need correct frame mounts and motor mounts. BB crosmember and clutch linkage BB heater box. Headers they are the worst problem. If I remember correctly that is all but I think my brain shuts down when I even consider that swap again.
oger is offline
post #3 of 4 (permalink) Old Jul 28th, 01, 06:06 PM
Gary
Add to the list: Z bar, shifter bracket, shifter linkage, fan shroud, fan shroud bracket, radiator,
Unreal is offline
post #4 of 4 (permalink) Old Jul 28th, 01, 06:10 PM
Gary
and...carb linkage, virtually all brackets and pulleys.
Unreal is offline
