electric choke - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 5th, 00, 04:01 PM Thread Starter
Red face
I know this is a simple thing to do but electrical stuff is not one of my strong points.My new 750 holley has an electric choke. holley included the wires for the choke but no where in the manual do they show how to hook them up.thanks, mike from savannah
zgator is offline
post #2 of 6 (permalink) Old Apr 5th, 00, 04:29 PM
If I remember correctly it goes to the positive side of the coil. That way it only gets voltage when the car is on.
MikeDF80 is offline
post #3 of 6 (permalink) Old Apr 6th, 00, 12:04 PM
mccorry's Avatar
Correct...that is how mine is hooked also...
You can ground the coil to the carb body...
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my car ---> www.mindspring.com/~mccorry
mccorry is offline
post #4 of 6 (permalink) Old Apr 6th, 00, 12:12 PM
Bryan Shook
When I installed the electric choke on my 4160 Holley, they specified that you need a full 12 volts to operate teh choke correctly. You DON'T have a full 12 volts at the coil. I got mine form a wire that was previously connected to my 2bbl.
Bryan Shook
Favorite Quote - Some people have shrinks. Some people have their garage.
My Father's 1968 RS 327!
My First Generation Camaro site
elcamino72 is offline
post #5 of 6 (permalink) Old Apr 6th, 00, 12:16 PM
Gene
I connected my choke (when I had one) to the fuse box on an ignition switch activated circuit.
Hugger Orange & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my new and improved website at:
www.geocities.com/gheatly
gheatly is offline
post #6 of 6 (permalink) Old Apr 6th, 00, 03:36 PM
I spoke with a local carb guy recently and he suggested a better way to hook up the choke. First, find a full 12 volt ignition source and then route it through the oil pressure sending unit. This will break the circuit anytime the engine is not running even if the ignition is on. This will stop the choke from opening when you're tuning or sitting with the ignition on. Sounds pretty clever but I haven't tried it yet.
'69 400SB, Richmond 5-speed; '99 HD Road King Classic
www.geocities.com/sdenning1
RockyMtnRacer is offline
